Foggy gauges
Old Feb 22, 2020 | 01:12 PM
Mrtelefoneman1's Avatar
Mrtelefoneman1
6th Gear
Default Foggy gauges
A couple of my gauges get foggy depending on the weather. Is there a fix for this or do I need new gauges? It's not terribly bad, just the bottom portion. Annoying more than anything else.
Old Feb 22, 2020 | 02:02 PM
Spartanden's Avatar
Spartanden
Mine do the same..... when I first start and ride, one or two of the gages might fog up. It goes away after a bit, and gages work properly. I would be interested if there is a problem, cure, or fix.
Old Feb 22, 2020 | 02:41 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Somehow, Harley has never figured out how to make the gauges waterproof. Fogging is very much normal with them.
Old Feb 22, 2020 | 04:39 PM
unclerog's Avatar
unclerog
Had the same problem on my 14 Heritage. the fog would come and go. So far no problems with the SG.
Old Feb 22, 2020 | 04:41 PM
packmen21's Avatar
packmen21
+1
Old Feb 22, 2020 | 06:53 PM
texasdw's Avatar
texasdw
That's normal for the tank mounted gauges.
Old Feb 22, 2020 | 07:19 PM
Uncle Larry's Avatar
Uncle Larry
Tank mounted has nothing to do with it ... if ever the term "they all do that" was appropriate it's now ... tank mounted, bar mounted and fairing mounted gauges are all susceptible to this problem .... and I speak from experience
Old Feb 23, 2020 | 06:37 AM
leachman's Avatar
leachman
Just get out and ride it.....if there is condensation then your not riding enough....lol
Old Feb 23, 2020 | 07:34 AM
HD Bobber's Avatar
HD Bobber
exactly right
Old Feb 23, 2020 | 03:53 PM
YZR's Avatar
YZR
They all do that.
