primary oil ??
Old Apr 7, 2020 | 08:14 PM
leachman's Avatar
leachman
HD offers a 80w140 for the primary I have been using is awhile now seems to work well.
I agree. I really like this fluid.
Old Apr 7, 2020 | 08:43 PM
skratch's Avatar
skratch
Originally Posted by seniorsuperglideE8
Wow, an 80W140 weight gear oil in the primary? I saw that on the bottle and I'm kind of surprised. In cold climates that would be as thick as molasses in the clutch plates.
Originally Posted by caulk04
Gear oils are numbered differently from motor oils. 20w50 motor oil is roughly the same viscosity.
that is one of the uses that they are selling it for. though for the price, i think i would go with something a little cheaper in the primary. your'e just gonna dump it in 5k anyway, and full synthetic is just overkill for that application.
Old Apr 7, 2020 | 10:10 PM
dforeid's Avatar
dforeid
I've tried so many different oils in the primary after the last 25 years and the best performing by far is HD Formula+. I'm an Amsoil guy in the trans. and engine, but Formula+ all the way in the primary. This is on Evo's, Twin Cams and the M-8. Nothing shifts better or has a nicer release than Formula+.
Old Apr 8, 2020 | 05:35 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by ultraglide12
just over one bottle
Ok. So probably slightly over full, but not hugely so. Your clutch isn’t swimming in oil.
If you’re sure your clutch is adjusted right, and therefore fully clamping when released, it’s almost assuredly a fluid problem. Which I find surprising, but not unbelievable.
One other is that you’ve a worn clutch that was barely holding, and the new fluid tipped it over the point. Can’t recall if you said anything about the clutch being new or not.
Old Apr 8, 2020 | 07:30 AM
smitty901's Avatar
smitty901
I ride year round in Wisconsin. Zero and below not uncommon and 10 degrees to 40's is fine . We did ride in 20 below this last winter for half the day. I had the same thing on my mine you do. It just did not seem to effect anything.
Old Apr 8, 2020 | 09:43 PM
ultraglide12's Avatar
ultraglide12
well i adjusted the clutch and all seems good so far. i think it feels better than it ever has. thanx all
Old Apr 8, 2020 | 11:52 PM
jammerx's Avatar
jammerx
I only use Amsoil 15w-60 (which I can't say there was a performance difference in from the 20w-50) or 20w-50. You can leave the synthetic in there for 10k with no problems. I've tried a bunch, years ago we ran type F in the primary. 20w-50 in all three holes just makes it too easy.
LQQK_OUT
Oil Archive (no new posts)
Oct 8, 2019 02:07 PM
campdreamer47
Apr 22, 2012 08:52 AM
WhiskeySierra
Mar 9, 2012 05:00 PM
Sancho
Jan 22, 2010 03:09 PM
bnsoftailrider
May 23, 2006 02:37 PM
