Loctite or not?
Old Nov 4, 2005 | 08:05 AM
Mikeeeeeeeeee's Avatar
Mikeeeeeeeeee
"Moderator & Connoisseur of Ice Cream"
Default Loctite or not?
Removed the front wheel yesterday to repair the wire for the lights on the fender.
Question is, the shop manual says nothing about loctite on any of the three nuts that hold the axle.
Do I need to? I torgue them to th proper specs.
Mikeeeeeeeeeeee
Old Nov 4, 2005 | 08:24 AM
Tripper's Avatar
Tripper
Default RE: Loctite or not?
I use blue loctite and torque wrench for most applications, but I'm not sure when or if to use red loctite.
Old Nov 4, 2005 | 08:27 AM
joe's Avatar
joe
i don't use alot maybe a drop (small) but if i take a nut or bolt out it goes on, with the exception of plastics.these bikes also need a going over at the end or the beginning of every season.nothing with a cotter pin but everything else
Old Nov 4, 2005 | 09:02 AM
Blue SOG's Avatar
Blue SOG
I use blue on the nuts you are talking about. Red loctite is considered permanent and cannot be removed without the application of heat. Not something you want to put on a "servicable" fastner.
Old Nov 4, 2005 | 09:22 AM
Mikeeeeeeeeee
After years of torching red loctite to remove, I know that I wouldnt want red on those nuts.
The reason I am raising this question is, I didnt see any on the nuts when I removed them. Nor on the studs / axle. And the manual says nothing about using it there.
MIkeeeeeeeeeeeeeeee
Old Nov 4, 2005 | 01:05 PM
jfanton's Avatar
jfanton
I've had the front wheel off my '97 softail a dozen times, and if memory serves, I loctite the clamp studs but not the axle nut. But putting BLUE loctite on the axle nut can't hurt. So, if in doubt, loctite it.
Just don't use RED!
Old Nov 4, 2005 | 02:04 PM
skos's Avatar
skos
I agree with Tripper, blue loctite and torque wrench for most applications
Old Nov 5, 2005 | 11:57 PM
Kess's Avatar
Kess
Hope you used the Blue Loctite for your cupholder!
Old Nov 6, 2005 | 12:48 AM
Mikeeeeeeeeee
ORIGINAL: Kess
Kess, I laughed out loud when I read that! What a good way to end an evening.
Mikeeeeeeeeeeeeeeee
30glock
2014-2024 Touring Models
11
Apr 6, 2015 02:18 PM
eagles350
EVO
15
May 6, 2014 09:49 PM
kaiser343
Oct 21, 2013 06:56 PM
fighthedude
May 23, 2011 09:07 PM
jnslim007
Mar 29, 2008 08:48 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
