Aftermarket security system
Old Nov 2, 2020 | 05:08 PM
123ozzie's Avatar
123ozzie
Default Aftermarket security system
HD makes a Smart Security System (#68200-07A) for bikes that use a manual key to turn on the ignition. Anyone try this out? I'm wondering if this will completely eliminate the need for the key. The description is a bit vague. Thanks
Old Nov 2, 2020 | 07:03 PM
DizzyDen's Avatar
DizzyDen
It won't eliminate the key. It disables the start circuit until the fob is in range
"After riding your vehicle, park and switch the ignition off with your key. Within 5 seconds the Security System will automatically self-arm, disabling your vehicle starter, ignition and electronic fuel injection (EFI)."
Old Nov 2, 2020 | 07:59 PM
123ozzie's Avatar
123ozzie
OK, so if I leave the ignition in either fork lock or off but unlocked, nobody could hop on the bike and start it without the key fob in hand, correct?
Old Nov 2, 2020 | 08:05 PM
boasty's Avatar
boasty
correct
Old Nov 3, 2020 | 04:57 AM
123ozzie's Avatar
123ozzie
Originally Posted by boasty
correct
Thanks, the lock portion of my ignition switch is worn and should probably be replaced/rebuilt. I haven't priced it out yet, but figured it's got to be at least a few hundred dollars. This security system could be a nice alternative.
Old Nov 3, 2020 | 07:29 AM
barneyboy's Avatar
barneyboy
Without a key, the forks can't be locked.
Old Nov 3, 2020 | 07:41 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Kawasaki has a funky system
The only time the key is removed is to open the gas cap or lock/remove the hard bags.
Otherwise it stays in the ignition all the time...
without the FOB, or the rescue FOB, the bike won't unlock the steering or power the ECU... but the key is left in the bike
Cooter383
Electrical/Lighting/Alarm
May 11, 2020 03:23 PM
Daniel K
Mar 6, 2019 07:21 AM
KiloGolf4
Aug 26, 2012 06:10 PM
workformetoo
Apr 27, 2008 09:53 AM
customrider31
Sep 20, 2006 08:52 PM
