Brake rotors
Old Dec 14, 2020 | 10:17 PM
tajar66's Avatar
tajar66
Default Brake rotors
Merry Christmas!
using a micrometer my rotors are measuring .20 minimum thickness is .16. I was planning to replace the pads should I do the rotors as well? I am thinking yes but a couple friends say they would replace them yet.
How thin would you go??
Old Dec 15, 2020 | 03:34 AM
eighteight's Avatar
eighteight
A resounding no
Old Dec 15, 2020 | 04:09 AM
d_slat's Avatar
d_slat
A resounding no
If you do the math, you still have 0.040" until you get to min. thickness. That's a lot of metal, which means there's a lot of life left!
Old Dec 15, 2020 | 04:16 AM
Hoginedgewood's Avatar
Hoginedgewood
Are you stopping good? Do they have a mirror finish? Do you have too much money?
Old Dec 15, 2020 | 07:12 AM
brohoss's Avatar
brohoss
question: could the rotor be turned, or that not an option?
Old Dec 15, 2020 | 07:14 AM
eighteight's Avatar
eighteight
If required it would be best to have rotor "ground" ( Blanchard or surface grinder ) rather than turned on a lathe
Old Dec 15, 2020 | 07:20 AM
brohoss's Avatar
brohoss
ok..thanks for the reply
Old Dec 15, 2020 | 08:20 AM
tajar66's Avatar
tajar66
I was thinking it wasn’t a lot left but apparently it is
Old Dec 15, 2020 | 08:21 AM
tajar66's Avatar
tajar66
I did it know you could resurface MC brake rotors
Old Dec 15, 2020 | 08:24 AM
tajar66's Avatar
tajar66
yes I am stopping well. They do not have a mirror finish some light groves. Money not an issue. If it were my truck I would turn or replace the rotors to have a fresh mating surface for the pad to bed on.
