Leak
Old Jan 21, 2021 | 07:06 PM
markdavidson's Avatar
markdavidson
Default Leak
So I dropped a cam in the King. Fired it up let her come up to temp . Took a short 5 mile ride to feel things out. When I got back to the house, the whole right side was covered in oil. Today I cleaned it all up and dried everything and warmed her back up. couldn't really find anything. Took that same short ride, running pretty hard bumping the rev limit a couple times... maybe a tiny weep from one of the pushrod tubes.. o-rings seat on heat cycle?
Old Jan 21, 2021 | 07:45 PM
roussfam's Avatar
roussfam
My money is on pushrod O-ring not seated properly. Same thing happened to me.
Jim
Old Jan 21, 2021 | 08:09 PM
Tcrafty's Avatar
Tcrafty
Not sure it's the same, but I had a similar thing happen.
Just had the cams changed in my RK and I keep a pretty clean white wall,if you know what I mean... LoL
After riding it home, I noted some oil spots around the tire's white wall. The kind you get when you leak while on the move. I couldn't see where it was coming from, but kept and eye on it. It didn't seem to be getting worse, so cleaned the tire. Haven't had anything since. Perhaps it could have been a pushrod tube? I thought it might have been some oil trapped on the frame somewhere from when he popped the side cover. A LOT of oil came out then and could have easily found a place to hide. I don't know, but it doesn't seem to be doing it anymore. YMMV
Old Jan 22, 2021 | 05:29 AM
jake24lt's Avatar
jake24lt
my bet is one of the push rod tubes didn't seat right.Or hopfully you didn't leave an o-ring out.
Old Jan 22, 2021 | 05:44 AM
Notgrownup's Avatar
Notgrownup
Marking its spot, new cam and all, bigger *****...
rasmukri
Mar 26, 2014 11:27 AM
Dusty Hawk
Jun 20, 2013 10:29 AM
paud
Sep 6, 2010 05:48 PM
PKellyMc
Jul 21, 2009 02:53 PM
Animal494
May 22, 2007 11:11 AM
