2013 streetglide....to raise bars 12 inches
Old Feb 15, 2021 | 09:34 AM
roadhog0227's Avatar
roadhog0227
1st Gear
Default 2013 streetglide....to raise bars 12 inches
this streetglide has ABS braking system...question is do i need to get dealer involved to install the longer brake cable if i do the rest of the bars work myself...or is this a total harley dealer job..I appreciate your input. thx Arend
Old Feb 15, 2021 | 10:03 AM
jory434's Avatar
jory434
I did all my own stuff on my ABS brake line swap. Search some threads here and youll get mixed opinions. In short, it can be done with no issues if bled correctly.
Old Feb 15, 2021 | 11:14 AM
roadhog0227
1st Gear
so Jory..when you say bled properly....I had understood from others that bleeding abs brakes requires specialized tool by harley and needs to be done by dealer
Old Feb 16, 2021 | 12:42 PM
dmonger's Avatar
dmonger
Originally Posted by roadhog0227
so Jory..when you say bled properly...I had understood from others that bleeding abs brakes requires specialized tool by Harley and needs to be done by dealer
I put 18's on my 16 FLHXS myself, which included all new lines. If you go to YouTube, Hill Country Customs has a couple of videos on replacing the ABS brake line; they also sell a little syringe and tubing needed to swap out your brake line successfully. It is entirely doable by yourself, but if you somehow manage to get air in your system, then Harley will have to hook it up to their machine to bleed it fully. But I am a horrible garage mechanic and managed to do it myself, so there's that.
Old Feb 16, 2021 | 12:43 PM
dmonger's Avatar
dmonger
Old Feb 16, 2021 | 03:17 PM
Crossbone Canuck's Avatar
Crossbone Canuck
I have put taller bars on both of my bikes and done the brake bleed myself with no problems. Follow the video above and you should not have any issues.
Old Feb 18, 2021 | 10:39 AM
jory434's Avatar
jory434
Main thing I can recommend is try filling the replaced line with brake fluid the best you can, then pump and bleed a lot. I bled 2 bottles of fluid through mine before I kicked the ignition on. Just to be sure.
Old Feb 19, 2021 | 09:46 PM
dgarber12771's Avatar
dgarber12771
When I went to order the cable kit for my 2011, Burly's kit for my bike says:
  • Kits require reuse of existing lower brake line
  • Black Vinyl for 13" Tall Bars kit does not include or require extended brake line
This is for ABS equipped bikes. When the kit arrived yesterday I confirmed that the only thing in it was a clutch cable, and the wire extension kit.
I'll be installing the 12" bars tomorrow, so I guess we'll see.
Old Feb 21, 2021 | 09:00 AM
casique's Avatar
casique
If you replace the brake line from the handlebar to the ABS module, there is no need for the HD dealer.
I bled my 2011 FLHX with an "ARES 70923-1-Liter Vacuum Brake Fluid Bleeder" last month after replacing the handlebars with Hill Country 14 inch Jarheads, and all is well.
Old Feb 21, 2021 | 09:21 AM
DwayneH's Avatar
DwayneH
Veteran: Canadian Forces
Folks, if you are going to be removing a master cylinder, whether it is for the clutch (hydraulic clutch), or brakes: NEVER PLACE THE COVER UPSIDE DOWN!!!! NEVER. Trust me on this. When you are removing the covers, make sure you hold them so they are oriented as though they were still on the bike. Place them down this way as well. If you don't do this, chances are very high we will see posts that start with: "So, changed my clutch/brake fluid, but now fluid is leaking from my Master cylinder cover". The process I just described, will stop that from happanening.
Mr D
Dec 1, 2022 06:53 PM
GriffinDenim13FLHX
May 2, 2019 10:15 AM
08HD
Dec 11, 2009 05:31 AM
SA315B
Jan 28, 2009 08:03 AM
Bluerose
Jan 1, 2008 12:08 PM
