security fob 4 digit code
Old Apr 7, 2021 | 06:31 PM
ag1971340's Avatar
ag1971340
1st Gear
Default security fob 4 digit code
For those of you do-it-yourselfers out there (like me) who don't want to have to make the trip to the dealer every time they want something done, let me relate my experience with removing the TSSM non-pushbutton security system on my '08 Ultra. This may work for other bikes, but I'm not a factory mechanic - so I can only confirm that this will work on '07 and later touring. One of the advantages of doing this yourself is that you can keep your original module (along with a printout of this post) and re-install it at any time without another trip to the dealer, or if the bike's new owner wants a security system.
The factory security system is contained within the Turn Signal Module (TSM), which becomes a Turn Signal Security Module (TSSM) when it is so equipped. If you are disabling the TSSM (do NOT want a security system on your bike) then you have a TSSM installed now, HD p/n 68924-07. This is a roughly cone-shaped device in a black plastic case, mounted vertically under the seat and to the right (starboard) side. Mine was held down with a silver metal clip. The first thing we need to do is replace this item with a NON-security equipped TSM.
So before you go hunting for the TSSM on your bike and removing it, buy the part you're going to replace it with - in this case, HD p/n 68920-07. They are $114 new from Harley, but I found many on eBay and bought one for $24.95 including shipping to my door. You will also need (highly recommended) a 2 amp (or so) motorcycle battery charger to complete the job safely.
Okay - now, we have everything we need to do the job completely. Find the TSSM under the seat of your bike, remove the clip, and lift it out. There will be TWO connectors plugged in to it; remove both. Note that one of the plugs is larger than the other - this is the input, ECM, and turn signal connector - we will use this again. The smaller plug is the output for pager and siren - tape that one up to protect it and set it aside for now. Plug the larger plug into your new TSM, and slide the assembly back into place, carefully storing the loose connector where it won't rattle or take too much wear.
Whoa. That's it?
Nope. If you try to start your bike at this point, it will rumble and die, and you'll be cursing me for life. The bike knows that the security system has been compromised, and is trying to protect you, the owner. Getting it to feel all warm and fuzzy about its new body parts takes another half an hour - which kind of discourages the swap-out-and-quick-getaway-routine by a more unscrupulous rider who just happens to be enamored with your new paint job.
In the next step, we're going to have the bike's ignition (and lighting) on for more than half an hour, so here's the part where we plug in a 2 amp battery charger to keep things live. With the battery charger hooked up, perform the following:
1. Be sure the ignition has been OFF for 15 seconds or more before starting the procedure.
2. Set Run/Off switch to RUN.
3. Turn ignition key on, do not start. Verify that the Check Engine Light and Security Light come on, and wait for them to go out.
4. Attempt a normal start with the Start button. Engine should come to life and then die. The Check Engine Light should light up and stay on.
5. Wait ten seconds. The Security Light now comes on. The ECM has now entered communication mode with the TSM for the next ten minutes. Look at your watch and do something else for the next ten minutes, but don't shut off the bike, let the battery die, flip any switches, or unplug anything electrical. Just polish the fenders or something.
6. In ten minutes, the security light will turn off. Within 15 seconds, turn the ignition key Off and back On. This Off-On motion should be crisp, completed in two seconds or less. The Security Light comes back on, and you have another ten minute wait.
7. When the Security light goes out again, repeat step six.
8. When the Security Light goes out this time, do the Off-On thing, then when the Security Light comes back on again, shut the ignition OFF. Wait at least 15 seconds, during which time you should be (carefully) unplugging your battery charger (unplug from the wall outlet, then from the bike, right...?).
9. With 15 seconds or more gone by, turn your ignition on, confirm the Run button, confirm neutral, and start your bike. You've created a happy marriage between your ECM and the new TSM, and you no longer have to worry about having a key fob or memorizing a security code. Now you can just worry about someone riding off with your bike whilst you're suckin down a brew in the local pub - use the fork lock!
If you're like me, you'll never remember all this two years from now when you're selling your bike, so print this out, take the battery out of your key fob, and put the fob, TSSM, and this paper in a ziplock bag and store it wherever you would go to look for it two years from now. Happy riding!
Hey guys, new here looking for some help. read this thread and there was mention of a 4 digit code and also something about transport mode. I couldn't find anything in the fob so can someone steer me in the right direction?
Old Apr 7, 2021 | 06:53 PM
hattitude's Avatar
hattitude
Confusing first post....
Not sure why you listed the procedure for marrying a new TSM/TSSM to your bike, just to ask a question about the 4-digit security code and transport mode.....???
If you switch from a TSSM to a TSM, you will not need to worry about the 4-digit security code nor the transport mode procedure, because they are both associated with the alarm and will no longer apply to your bike...???
Obviously I've missed something about about your post, so in brief...
The 4-digit security code, is the code you enter into your bike to bypass the security system when you want to start it, and your key fob died, or is not with you.... The procedure for setting up your security code and entering the security code is in your owner's manual and/or the online owner's manual via the HD website.
Transport mode basically disables the motion sensor portion of your alarm. It allows you to tow the bike on a trailer, not have the alarm sense movement from being on the trailer, then constantly going off, and running down your battery. Again, the procedure is in your owner's manual and/or the online owner's manual available via the HD website.
I think that's what you wanted to know.... but not sure... hope it helped..
Old Apr 7, 2021 | 07:02 PM
Hoginedgewood's Avatar
Hoginedgewood
Hi!
nice post.
Old Apr 8, 2021 | 08:20 AM
skratch's Avatar
skratch
except, there is no 4 digit code. it is 5, and no zeroes.
Old Apr 8, 2021 | 08:34 AM
TriGeezer's Avatar
TriGeezer
Welcome.
Old Apr 8, 2021 | 09:16 AM
hattitude's Avatar
hattitude
Wow... I totally spaced out on that... glad you caught it...
Old Apr 8, 2021 | 09:34 AM
IKnowNot's Avatar
IKnowNot
Except for the last two lines (the questions) the entire post was a copy paste job.
Don't believe the OP is real computer savvy.
Nexus9 posted this on 02-12-2011 here:
https://www.hdforums.com/forum/ignit...ems-07-up.html
Nexus9
53
Jan 8, 2025 11:05 AM
sdecgreen
2014-2024 Touring Models
Feb 16, 2021 08:49 AM
Vt Rider
Jan 25, 2011 09:28 AM
mrsr71
Mar 30, 2008 06:16 PM
