need some major help please
Old Jun 20, 2021 | 01:47 PM
Skeeter11's Avatar
Skeeter11
Stage II
Unhappy need some major help please
i have a 2000 ultra classic.here recently my speedo would drop to 0 and then back up to speed.no other issues with other gauges at all.i took it to the harley dealer and they couldnt replicate issue.spent 5 hours and couldbnt get it to do it again.i picked up bike and as soon as i left the service department and hit the highway it did it again. supposedly no DTC where present...anybody had this issue before and if so how did you fix it..im affraid we may get stranded somewhere.
thanks
Old Jun 20, 2021 | 02:19 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!!
Old Jun 20, 2021 | 02:28 PM
kel03's Avatar
kel03
Maybe https://www.hdforums.com/forum/elect...placement.html or https://www.hdforums.com/forum/touri...replace-4.html
Old Jun 20, 2021 | 02:44 PM
mskirwin's Avatar
mskirwin
Welcome from Philadelphia, enjoy the ride.
Old Jun 20, 2021 | 02:54 PM
TriGeezer's Avatar
TriGeezer
Welcome.
First I’d try cleaning the speed sensor.
Old Jun 20, 2021 | 03:39 PM
dodger413's Avatar
dodger413
next time the speedo gets flakey, try your directionals to see if they work or not.
metal filings on the speed sensor, or a defective speed sensor causes the problems at the same time. an easy fix.
good luck
Old Jun 20, 2021 | 04:19 PM
Taxgod4u's Avatar
Taxgod4u
Bad ground wire?
Old Jun 20, 2021 | 06:30 PM
EdwardK's Avatar
EdwardK
Check and make sure it's plugged in n the back. I spent days chasing an intermittent and inaccurate fuel gauge. Turns out the plug was coming loose on the back of the gauge.
Old Jun 20, 2021 | 06:33 PM
internet troll's Avatar
internet troll
Originally Posted by TriGeezer
Welcome.
I worked as a service writer in the early 00's and saw this frequently. Speedo would flip out, then be normal, no way to predict it. As others here have said, small metal shavings would build up and get stuck on the sensor. Try changing your oil and cleaning the sensor.
Old Jun 21, 2021 | 06:23 AM
Skeeter11's Avatar
Skeeter11
Stage II
Originally Posted by TriGeezer;[url=tel:20005581
20005581[/url]]Welcome.
then that’s what I will do today. Directional work and cruise works,(until Speedo drops,) and then all is fine once I’m back up.. thanks for the advise as Harley spent 5 hours and couldn’t replicate my issue..
