12" or higher bars
Old Sep 15, 2021 | 08:11 PM
GmanHawaii's Avatar
GmanHawaii
Default 12" or higher bars
Looking at installing 12" LA Choppers Twin Peak bars. Cant seem to get a straight answer on whether or not I will need to extend cables, brake lines, etc. Anyone change their bars on a 2021 with cable clutch?
2021 Street Glide Special
Old Sep 16, 2021 | 06:26 AM
BelchFire's Avatar
BelchFire
I don't know about LA Choppers, but KST bars will tell you that any Street Glide (Ultra, etc) 2014 or over, will go up to 12" without cables. You WILL need a wiring extension, but that was only about $35 and SUPER easy to install .... snap, snap.
Old Sep 16, 2021 | 09:10 AM
tully_mars's Avatar
tully_mars
Just did a brother's 2021 Street Glide with Dominator 12" bars and the stock clutch and brake worked fine. I don't think 14's would work though. I have KST 12" on my bike and the Dominator's are just slightly narrower, but the height seems to be about the same.
Old Sep 16, 2021 | 09:47 AM
NoRegerts's Avatar
NoRegerts
I have 12s on my 20 SG and I ran the stock lines but had to extend the harness. I got this plug and play kit from Hill Country Custom Cycles. Absolutely worth the little added cost. Anything more and I would have had to get new lines. I had to reroute them and things got tight.
Old Sep 16, 2021 | 09:48 AM
rnl_1200C's Avatar
rnl_1200C
I have the 12' LA Choppers Twin Peaks - no cable or line changes at all
Old Sep 16, 2021 | 01:25 PM
DerekG's Avatar
DerekG
12s should be fine. we put 14 kst 1 1/2 bison bars on my 21. These bars are wide with a long pullback, had to reroute the cables. It does work, but the clutch cable is tighter than I'd like. Definitely getting new cables when they're available.
Old Sep 16, 2021 | 01:36 PM
GmanHawaii's Avatar
GmanHawaii
I see theres an extension kit for clutch cable
Old Sep 16, 2021 | 01:41 PM
lp's Avatar
lp
As far as those Canbus extensions... all over ebay too for cheap(er).
https://www.ebay.com/itm/13348688426...Cclp%3A2047675
Old Sep 16, 2021 | 03:17 PM
Demons Cycle's Avatar
Demons Cycle
Former Sponsor
This is true. Simply and easy install with 12" bars.
Thanks.
Old Sep 16, 2021 | 08:20 PM
OKIE17GLIDE's Avatar
OKIE17GLIDE
I had 12's from a buddy put on my '17 SGS, nothing needed to install them.
