Sirius Bracket
Old Aug 10, 2007 | 08:41 PM
vinniez's Avatar
vinniez
Default RE: Sirius Bracket
You need to be careful. Some of the radios are not 12 volt. Some are only 5 volt. you will need to check this out before you do the orange wire. I just plugged mine into the lighter.
Old Aug 11, 2007 | 09:35 AM
gilbos440rt's Avatar
gilbos440rt
All the sirius sat recivers I've had were 12 volt, the XM's were the one with the reduced 5 something Volts setup 12 volts kill them quick!
Old Aug 11, 2007 | 06:53 PM
gman's Avatar
gman
ORIGINAL: gilbos440rt
wouldn't you just know my luck. I bought a Sirius Starmate 4, and when I went to hard wire it in, discovered it runs on something like 4.5 volts. Installed a cigarette lighter receptical under the fairing and secured the Sirius power cord (that cuts the power from 12 v to 4.5v)to it with wire ties to ensure it doesn't come loose.Dam chinese junk. Oh well, works great now, just a pain.
Old Aug 12, 2007 | 08:22 AM
nedster's Avatar
nedster
sirius makes a mount just for a motorcycle, it comes with a built in resistor to drop the volts down from 12 to 4.5. It also comes with a antenna,bracket aux cable for 70 bucks.
Old Aug 13, 2007 | 11:13 AM
Rotti1's Avatar
Rotti1
Thanks for the replys. I think I'll stay late at work and make one using the bolts (get loger ones) for the clutch side.
Smitty
marlinman1
Dec 1, 2009 08:48 AM
williamfrog
Dec 28, 2008 10:57 AM
yoopermjm
Jan 5, 2007 12:37 AM
ClassicBob
Dec 9, 2006 05:34 PM
my06uc
Apr 2, 2006 01:21 PM
