Issues w/ stalling and ?'s on an ECU swap
Old Nov 8, 2021 | 01:32 PM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by 07UltraGuy
Additional research suggests that the IAC module itself is the predominant cause of this issue (especially for the '07 models).
It's only a $50 part, which is far better than a new tuner and/or a new ECU!
Swapping this part out myself will still be cheaper than the hour+ labor for a shop to just diagnose it, and it will be new; so even if it isn't the root cause, I'll be ahead...
checking the screw is free
Old Nov 8, 2021 | 02:12 PM
07UltraGuy's Avatar
07UltraGuy
Yes, but the screw position will affect idle speed at all times, not just when returning from higher RPM's.
It idles fine when started, just not when coming to a stop, so all indications that can find point to a sticking/failing IAC.
I have cleaned it multiple times and there has been no change in performance, hence the liklihood that it is the root cause (or at least part of the root cause).
Old Nov 8, 2021 | 02:27 PM
Ed Ramberger
You do not understand how the system works. On decel the IAC must open to prevent stalling as the throttle is shut. If the screw has backed out, the IAC can’t open fast enough and it stalls. It’s your money but i would recommend you check the screw first. You started this thread ready to buy a new efi system. Do your due diligence instead if getting out the parts shotgun.
if the IAC were stuck it would idle higher as it warmed up. You say it starts fine and idles fine except for decel.
Old Nov 10, 2021 | 09:55 AM
klammer76's Avatar
klammer76
Originally Posted by Andy from Sandy
ECUs do hold the VIN and miles covered amongst other things.
Have you checked the IAC is working properly against the electrical diagnostic manual?
Put a stock air cleaner on and remove the power commander. ECM already holds stock tune I believe as PC is a piggy back device?
In 2019, I converted my 2002, FLHTC (carbed) to Delphi, EFI from a donor 2002 FLHTCI. Switching the ECU was a none issue with the vin# and my bike. I was concerned about it but it was fine. Converted the donor to carb and installed my carbed ECU and ignition in that bike.
Old Nov 12, 2021 | 09:42 AM
hattitude's Avatar
hattitude
For an owner to switch an ECU, particularly if you did not have a TSSM (security) and only had a TSM... was easy with early twin cams....
IIRC, I believe it was 2004 when there were some changes made to the speedometer/ECU/TSSM interface.... There were user available procedures to marry TSSMs, TSMs, and ECUs together, but they were time consuming and needed to be very precise in execution...
Then in 2006/2007 the bikes switched from the TSSM to the HFSM (hands free security module) and from an ECU (open loop EFI) to an ECM (closed loop EFI), things became even more complicated....
Currently with Canbus and BCMs.... it is impossible for an owner to change their ECMs, without dealer assistance, unless they have the proper computer diagnostic tool ($$$)...
Old Nov 13, 2021 | 12:26 AM
klammer76's Avatar
klammer76
2004 was their first first flirtation with canbus which screws everything up. I have a TSM not a TSSM on my 2002.
rockon
May 13, 2014 10:04 AM
gdhugh
Oct 6, 2011 12:20 PM
sublime_ac
Jul 26, 2009 01:17 PM
creep1
Sep 2, 2007 08:54 PM
GenoRKng
Feb 24, 2007 07:25 PM
