Engine Temperature Sensor replacement
Old Jun 27, 2020 | 11:25 AM
Daniel de la Cruz's Avatar
Daniel de la Cruz
Stage I
I have a 98’ rkc and changed the head temp sensor by raising the fuel tank with a block of wood to hold it up. I don’t care what anyone says, at about every 30k the bike will start running as you’ve described. Trust me change that sensor I found this out on another forum after changing tps sensor, crank position sensor, fuel filter, and fuel pump sending unit, basically wasted some money. I did the job myself, take your time, but you are definitely on the correct track. Try that before anything else, don’t mess with tps settings it’s a real pain trying to reset to factory settings OR as in my case different settings due to bigger fuel injectors, screaming eagle kit, a dyno, a different cam, and true duals. As in the forum I read, trust me, change that damn sensor and you will have a sweet running bike again IF you didn’t mess with any idle settings.
Old Jun 27, 2020 | 12:08 PM
GalvTexGuy's Avatar
GalvTexGuy
Originally Posted by Daniel de la Cruz
I have a 98’ rkc...
First post and you’re responding to an almost 13-year-old thread. Nice job!
Old May 25, 2021 | 07:24 PM
yelrah1965@gmail.com's Avatar
6th Gear
Default Where to purchase
where did u find a sensor? I need one but cant find one to ship to canada.
Old May 25, 2021 | 07:31 PM
6th Gear
mke125125
Oct 27, 2023 07:53 AM
glsec507
May 16, 2017 02:49 PM
LonewolfFrank
Nov 15, 2015 08:00 PM
Mpbrink5
Engine Mechanical Topics
Jun 23, 2014 10:54 AM
alazlo
Jun 11, 2007 01:49 PM
