2018 RKS front turn signal problem
Old Apr 10, 2022 | 08:26 PM
Bigsean's Avatar
Bigsean
Default 2018 RKS front turn signal problem
2018 RKS. Installed new carlini 16 inch bars and now the front turn signals just stay on solid white like running lights. They won’t flash when I hit the switch. The rear is fine. I’m pretty sure it’s not my wiring because there on they just won’t flash. It sets codes for front and left turn signals. There LED and worked fine before the bar install. It wouldn’t start at all when I first finished the job but I think it was a battery issue. I had no power at the starter switch. I’d hit the button and nothing would happen. I tried to jump it with my charger/jumper. It’s mainly for cars but. The setting on it is 12volt 60 amp/jumpstart. Everything flashed a few times like the bike didn’t like it so I stopped. Maybe I damaged something? I changed the battery and now it’s fine but still the front blinkers just stay solid white and won’t blink. What is going on with it? Please help if you can. I’ve checked everything multiple times. Switches, wiring im at a complete loss on these turn signals.
Old Apr 10, 2022 | 09:02 PM
Hawg Runner's Avatar
Hawg Runner
I would pull the lights and turn the hazards on, with a test light see if you have any juice to the signal side.
Old Apr 11, 2022 | 03:52 PM
Bigsean's Avatar
Bigsean
Interesting. What do you mean pull the lights though? Like pull the bulbs out? And if there is no juice to the signal side?
Old Apr 11, 2022 | 04:23 PM
Hawg Runner
Yep, or if you can stick the probe into your connector without damage it.
Old Apr 11, 2022 | 08:05 PM
Bigsean's Avatar
Bigsean
Sure. I will try that. Thank you. But I’m not sure what that will tell me. I already know they don’t blink. And it’s both sides. What would I replace?
Old Apr 11, 2022 | 08:17 PM
Hawg Runner
If you have current it's the bulb, if no current I would back track each connecter, maybe forgot to plug one together. I did that when I pulled my inner fairing and my heated grips were not working anymore, back tracked and found I forgot to plug one connecter up. Do they work with the hazards on? I found that from now on with that kind of work I'm taking pictures and tagging each connecter I take apart with matching paper key tags. I just saw you have a RKS, perhaps something inside the headlight bucket is not hooked up? Got a manual?
Old Apr 11, 2022 | 10:06 PM
Bigsean's Avatar
Bigsean
They do not work with the hazards. I took pics, video and tagged all the connections with tape and wrote on the tape where they go. I also marked everything with different colored paint markers. If one wasn’t plugged in it wouldn’t work at all. I was extremely careful. I also double and triple checked inside the headlight bucket. It’s also not the bulbs because I’ve tried other bulbs and they do the same thing. I have this weird feeling it’s something that has to do with when I jump started it. There’s no other issue though. I have an apt. With a tech later this week so hopefully he can figure it out. I’ll definitely update this thread when I find out. I wonder if it could be farther back in the harness. Not sure how though. They worked before the bar install. I did remove the seat and tank but… I’m just at a loss.
Old Apr 12, 2022 | 04:58 AM
Redbeard719's Avatar
Redbeard719
What diagnostic codes are you getting?
Did you check fuses?
Old Apr 12, 2022 | 05:21 AM
Hawg Runner
Sure not a pinched wire at the switch pack when reinstalled on the new bars? Perhaps a wire not pushed in enough in a connecter or in wrong slot? When the lights are on are they looking like regular running lights or brighter like signal light? Might be the wire is switched around?
Old Apr 12, 2022 | 07:55 AM
Bigsean's Avatar
Bigsean
Codes B2141 and B2146. I didn’t check fuses though because because someone on here said it doesn’t have fuses for the blinkers or an old school relay either. All controlled through one of the BCMs. I will look in there though just to be sure.
