Is this normal?
Old Apr 29, 2022 | 11:11 AM
hattitude's Avatar
hattitude
Originally Posted by Ssitruc
Future reference, all you gotta do is curl your finger around the pipe and push the strap into the worm screw, and start turning the screw... it'll pull the strap in and tighten right down.
Unless its been over tightened and is stripped...
This is basically all you're dealing with..
Originally Posted by Maurice1
Thanks. I knew I was going to the shop for something else. Besides, I did wrap fingers around the band tight, then turned screw but it did not catch. Problem apparently was band not even connected! Has to go into slot behind screw or something like that from what I remember.
That's what several people have mentioned.... stripped, or not connected as yours were....
If you get a hose clamp, watch as you unscrew it until it comes apart, like the top clamp in the above pic..... Then fit it back together... you'll totally get it... very easy to do, once you realize what needs to be done...
Glad it was a cheap, easy fix...
Old Apr 29, 2022 | 11:52 AM
brakeless's Avatar
brakeless
[QUOTE=Highway Handler;20585842]
Looked at it again now that I know it's the hose clamp and tried squeezing band while turning screw but it won't "catch" the band. Will let shop tighten.
thanks for the posts all. It just didn't register what it was. Guess thinking hose clamps were for..hoses only.[/QUOTE]
Hose clamps are not just for hoses, the same way loctite is not just for locks.
Reminds me of the time a few drops of loctite in the key hole can really make that lock secure.
Seriously don’t try it.
A few drops of super glue on the door handle of the hateful neighbor's car makes for entertainment though.
Old Apr 29, 2022 | 12:11 PM
Maurice1's Avatar
Maurice1
Doesn't make sense. Loctite is not for locks.
Old Apr 29, 2022 | 12:22 PM
MotoJockey's Avatar
MotoJockey
[QUOTE=Maurice1;20586018]
Stealing a quote from one of you other threads........ "I guess I take words literally, and that confuses me sometimes."
I think you may be right, you may need to relax a bit and enjoy the good hearted banter in these forums. See a little "Gray" sometime.........
Old Apr 29, 2022 | 01:33 PM
Maurice1's Avatar
Maurice1
[QUOTE=MotoJockey;20586054]
I enjoy a good laugh like most. Has to make sense though.🤭
Old Apr 29, 2022 | 01:51 PM
Highway Handler's Avatar
Highway Handler
I think the name of their product (Loctite) is misleading.
I wish I knew that before I put in in the keyhole of a guy's lock at work. Boy was he pissed and he never knew what the problem was.
gpeade
Aug 20, 2021 04:13 PM
Ridetothehill
Mar 9, 2021 05:23 AM
izhd
Jan 14, 2016 09:41 PM
rambo11
Jun 25, 2007 04:04 PM
raym
Exhaust System Topics
Apr 9, 2006 03:20 PM
