Brake Cable Question
Old May 17, 2022 | 01:10 PM
DL Jones's Avatar
DL Jones
3rd Gear
Default Brake Cable Question
I am looking for help! If anyone in Touring Land may know either who may have manufactured this type of system or if you know someone that can make a longer SS braided cable for this system without having to replace the entire system, is what I'm looking for.
I am replacing my factory 7.5" bars with 10" bars and was told I would not need new cables on my 09 Ultra Classic but for whatever reason they will not fit, no matter how much I reroute the cables. I am 2" short (reserve your comments) on my brake cable but looking at it, it separates from the block connection using a simple male/female connector (see the pic) - very smart! I haven't seen this system on anyother bike and am unsure where to search and how to search for it. I basically need a 23-24" cable with a female connector on one end and banjo bolt for the master cylinder on the other. See the attached pics.
Any assistance would be greatly appreciated!
Old May 17, 2022 | 01:57 PM
eighteight's Avatar
eighteight
Barnett ( among others) will fab up anything you desire
Old May 17, 2022 | 02:16 PM
RKZen's Avatar
RKZen
I originally had the H-D braided brake and clutch lines. I recently replaced them with Magnum Shielding lines. They can make them +2" than OEM or whatever length you need. They have SS finish, as well a a chrome finish called Sterling Chromite and chrome fittings.
Old May 17, 2022 | 02:23 PM
eighteight's Avatar
eighteight
Wonder if a P/O cut off the stock junction and added a compression fitting ( as opposed to a flare)
Guess you`ll find out when you take it apart
Old May 17, 2022 | 02:24 PM
OkieBill's Avatar
OkieBill
Russel also makes brake lines - both in stock format and whatever length required. Swapped mine over to Russell several years ago with the age of my ride and original brake lines (rubber) starting to show weather checking.
Old May 17, 2022 | 02:31 PM
WONKEY's Avatar
WONKEY
I 2nd this post, I used Magnum Shielding when I put new bars on my 04 fatboy and will use them again when I do my bars on the 14 SGS. great company to work with,
Edit: Here is mine from magnum shielding, this is on my 04 fatboy and I just did the bars last year.
Old May 17, 2022 | 02:53 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Your HD dealer should be able to help. I got my matching braided clutch line (not cable) from the dealer longer than stock when I changed the handle bars. They asked if I needed brakes lines (not cables) and my stock lines were long enough, so I know they offer them also that match stock.
Good luck
Old May 18, 2022 | 07:38 AM
Hawg Runner's Avatar
Hawg Runner
I am not going to comment on why folks keep calling a brake line a cable. Oh wait, I just did.
guuby
May 30, 2016 09:24 PM
edizzle
Apr 13, 2014 05:52 PM
kamut
Aug 23, 2012 07:36 PM
sclair
Sep 3, 2009 04:11 PM
DanielBoone
Sep 21, 2008 09:42 AM
