Handlebar slip
Old Jun 19, 2022 | 03:20 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default Handlebar slip
I just installed some 12 inch bars on my road glide. The riser pin had to be done away with. I'm a little concerned about the bars slipping, this is my first experience with changing bars. The new bars are knurled and I torqued the clamp bolts to spec. The install went great and the bars look awesome. As I said just a little concerned without that pin being in the riser but it seems to be common practice for the aftermarket to do away with it. I don't know maybe it's more of a location pin for installing the bars during assembly at the factory. Have any of you guys ever had 12 inch bars slip?
Old Jun 19, 2022 | 03:39 PM
Sam2010's Avatar
Sam2010
I recommend tightening them by hand over spec.
Everytime I tighten handlebars to spec. they slip. Example trying to pull the bike backwards or push it forwards.
Old Jun 19, 2022 | 04:11 PM
Spartanden's Avatar
Spartanden
I have done this on some dirt bikes way back when. If I had bars slip, I would take the upper riser off and take a flat chisel and "knock" some ridges in the riser. Not a hard whack, not deep ridges, but just 2 or 3 on each riser that would grip the bar when tightened down. That solved the problem for me. Just a suggestion. Try at your own risk!!
Old Jun 19, 2022 | 05:41 PM
Ultra103's Avatar
Ultra103
Gorilla Grabber top clamp will eliminate problems. I used a similar (but much cheaper) copy. Works great.
Old Jun 19, 2022 | 06:39 PM
Jshopes's Avatar
Jshopes
ive got the yaffe clamp on mine. its got 3 set screws in it. you can put set screws in yours. my bars have never slipped with this setup.
Old Jun 19, 2022 | 07:27 PM
dontdropit's Avatar
dontdropit
I bought a gorilla grabber and it made contact with the back of the gauges, I would have to push down on the gauges and force them into place. I wasn't going to do that. The bike is a 2020 road glide. I may just pull the wires back on the left side and drill and tap it for a threaded pin, just for peace of mind. I'm having no issues but I want to feel comfortable that I won't get 500 miles from home and my bars slip on me.
Old Jun 19, 2022 | 08:33 PM
Spartanden's Avatar
Spartanden
Tapping the clamp and using a set screw is something I had not thought of. Good Idea!!!
Old Jun 20, 2022 | 09:03 AM
lefty33's Avatar
lefty33
Yup...the Yaffe Super Riser Clamp (1.25") is the one I use as well on my Glide with 12" bars.
Old Jun 20, 2022 | 09:23 AM
62hdbiker's Avatar
62hdbiker
I take a center punch with the cap off and punch the bar on a angle- which causes a raised burr - sorta like the chisel referenced above. Works perfectly
NoRegerts
Apr 13, 2011 02:01 PM
BlueNoser
Sep 26, 2010 05:12 PM
brettnbama
Jul 6, 2010 11:45 AM
kelton3
Mar 28, 2008 08:02 PM
flpops
Sep 5, 2007 03:24 PM
