2011 Ultra 103 Ping?
Old Aug 14, 2022 | 08:26 AM
stupidbaker57's Avatar
stupidbaker57
Stage III
Default 2011 Ultra 103 Ping?
I have a 103 25,000 miles. At speed of 55 thu 70+ I hear a "ping" sound. If I speed up a little, the ping goes away until I'm back to cruise speed. If I slow down a little, the ping goes away until I reach cruising speed again. Only happens when cruising. I have checked for vacuum leaks and found none. I have installed "rocker stoppers" in the vale train. After this is when I heard the ping.
Old Aug 14, 2022 | 09:05 AM
SpiderPig's Avatar
SpiderPig
https://www.dkcustomproducts.com/fl-...vied-10-nr.htm
Old Aug 14, 2022 | 10:10 AM
memphisharley's Avatar
memphisharley
may want to revisit the install. may be pushrod making slight contact in rocker plate area or maybe hitting the top of pushrod tubes.
Old Aug 15, 2022 | 05:34 AM
stupidbaker57
Stage III
I did not remove the rocker
assembeley to install the brass tubes. I just removed each bolt one by one and installed the tube.
Old Aug 15, 2022 | 07:09 PM
btsom's Avatar
btsom
A true ping at low power settings (constant speed cruise) is rare. I would check things rattling. My son has the same year machine you have and his engine to frame link loosened on the frame end. If the engine shifted under higher power situations, the noise stopped. You might have a loose muffler bracket, the one on the bottom of the transmission side cover is another bolt that loosens frequently If an exhaust pipe has shifted enough to contact a foot board, you would probably feel that in your foot. It could be a fairing bracket loose or broken. Next time you hear it, put a finger on the brake lever, then the clutch lever and see if the noise stops with either. Try putting pressure (pulling and pushing) on the windshield/fairing. Try pushing the ends of the mufflers from side to side, then up and down. Any squeak or rattle? The heat shields on the header pipes might be squeaking. Have you added any after market equipment? Recheck that for tightness.
Old Aug 15, 2022 | 07:25 PM
memphisharley
op mentioned the "ping" started "after" the rocker locker install.
Old Aug 15, 2022 | 07:45 PM
btsom's Avatar
btsom
Re-read the OP's post. He installed rocker lockers in an attempt to stop the noise, and it didn't work.
Old Aug 15, 2022 | 08:42 PM
memphisharley
his last sentence says so. anyway..I'm done. op..good luck with her!
tafdeluxe
Apr 30, 2022 08:02 AM
N1265
Jul 28, 2019 10:44 AM
Fatboy1389
Sep 21, 2016 09:15 AM
1BADHD
Feb 27, 2012 04:51 AM
TickTock
Jul 27, 2010 12:53 PM
