TPMS alarm
Old Apr 24, 2024 | 03:05 PM
TGH518's Avatar
TGH518
Did you figure this out with TPMS losing signal sometimes? When I think back it was intermittent at first like every several days, now it's everyday when the tire hits 44PSI. I did notice it after adding after adding a CD tail light.
Old Apr 25, 2024 | 07:46 AM
cactusred's Avatar
cactusred
After a tail light change interesting. I had changed a tail light and the installed filler lights from CD. Kinda wonder if the BCM is sensitive to resistance changes in the light circuit and if one of our CD lights while it works it just a little more sensitive and enough to wig the BCM out, but strangely enough not enough to throw a code, unless it goes back to the wifi the light is putting out in some cases is enough to overlap the tpms signal and cause it to lose its mind. Regardless the bike was not this way from stock only after CD upgrades.
Old Apr 25, 2024 | 09:36 AM
TGH518's Avatar
TGH518
mine throws a code, I can’t remember the number but i looked it up, code was communication lost TPMS rear.
glebo
Jun 21, 2024 11:41 AM
Tom T-Bird
Jun 13, 2022 07:54 PM
Nedday
Wheels/Tires
Jul 21, 2018 05:08 AM
mazz
Screamin Eagle CVO Models
May 26, 2017 03:35 PM
mark10
Sep 9, 2011 03:11 PM
