Jerking, sputtering, and dead.
Old Sep 6, 2022 | 11:09 AM
bm11's Avatar
bm11
Bike is carbureted. No throttle by wire. Only sensors are Crank and MAP.
Scratch that then!
Old Sep 6, 2022 | 01:25 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If the engine cranks over but won't start, check the crank position sensor, this reads the notches in the flywheel and sends signals to ECM to initiate ignition and run modes.
Old Sep 6, 2022 | 01:57 PM
hardheaded's Avatar
hardheaded
I would have to agree , the crank position sensor could be bad, But could be coil too. The sensor is cheaper.. Or swap with a known good sensor before buying one.
Old Sep 6, 2022 | 02:02 PM
Max Headflow's Avatar
Max Headflow
Could also be the ignition module or simply a broken wire.
Old Sep 6, 2022 | 02:59 PM
Oko's Avatar
Oko
At first I thought this was a thread on the financial health of the Motor Company.
Cross thread points?
Old Sep 6, 2022 | 03:29 PM
FlamedFXR's Avatar
FlamedFXR
Check for codes would be my first move.
Old Sep 6, 2022 | 08:34 PM
Rounders's Avatar
Rounders
Always a good idea. But has never helped me on a carbed bike with electical problems just like this. Which for me were cpk and coil.
CAM sensors were also gone by 2006. I think midyear 2001, for fuel injection. or they went away with M&M.
Old Sep 7, 2022 | 09:10 AM
cycleman11's Avatar
cycleman11
Did the bike run fine at some point, or did somebody work on the bike and this event started. We need more info to help you out.
Old Sep 7, 2022 | 11:57 AM
hardheaded's Avatar
hardheaded
You figure this out yet ? Let us know.
Old Sep 7, 2022 | 12:07 PM
Max Headflow
My guess... Carbed 124 SnS motor probably has a Super G carb.. Motor ate a backing plate screw..
