On going issue
Old Sep 11, 2022 | 01:13 PM
Lightningfast12's Avatar
Lightningfast12
Stage III
Default On going issue
I have a 2012 road glide ultra with stage one upgrades Thunder Max tuner, Vance&Hines true duals, and K&N ire filter. Recently replaced rectifier/regulator because of voltage issues and bike will run great. My issue is I'm getting 3 codes and bike goes into limp mode. I reset the , run great for a day then got P1511,P2101 and P2176 I'll reset runs great for a day then throw them again. Cleaned pins and greased connections on both ECM and throttle body, same issue . Any thoughts anyone?
Old Sep 11, 2022 | 04:06 PM
Dseago1969's Avatar
Dseago1969
All three point towards the throttle body actuator. Check your connections behind the air filter.
Old Sep 11, 2022 | 04:50 PM
Lightningfast12
Stage III
Default Possible actuator
Are you referring to the motor and gear set on the left side of the throttle body looking at it from the air cleaner side. The only other connection behind the air cleaner are the injectors
This connection
Old Sep 11, 2022 | 05:28 PM
Vernal's Avatar
Vernal
That is the one he was referring to. If that doesn't work check continuity on all the wires in that connector.
Old Sep 11, 2022 | 07:07 PM
Screamin beagle's Avatar
Screamin beagle
This connection
check those wires and pins inside that plug. Looks like it's been stretched and under some tension so the possibility of pin backing out or coming disconnected from the wire is possible. Theres an extension kit available usually can be found on ebay.
Old Sep 11, 2022 | 07:46 PM
Max Headflow's Avatar
Max Headflow
I'm by no means a throttle by wire guy but I do know a little about closed loop servos.. The errors you are getting appear to indicate that the throttle servo is not operating correctly. The first is simply going into power management mode due to the other 2 errors. The ECU seems to be having problems closing the loop at idle.
You say you had regulator problems.. I suspect that it was due to the battery voltage going too high. Chances are that the might have burned / stressed part of the electronics. You probably already figured that out.. OK, So which part? The ECM or the Servo in the throttle body. I would guess that since you are stage 1, you could try the stock ECU and see if the error returns. If it does, it's likely the throttle body. If it don't it's the driver in the Tmax.
Since you didn't get a "P2135 TPS Correlation Error" I'd suspect the Tmax driver but you might get away with a clean and lube of the guts inside the throttle body control.
As usual, if you blow anything up, I disavow everything I've wrote here..
Old Sep 12, 2022 | 07:59 AM
Lightningfast12
Stage III
Default Issues
Thanks for your input and my people said your totally in the clear if I do blow up.
Old Sep 12, 2022 | 08:05 AM
Fireball Jack's Avatar
Fireball Jack
You have people that give you the green light to be blown up?
Mo910
General Topics/Tech Tips
Sep 9, 2024 11:20 AM
XLR8_2_FAST
Jul 28, 2019 07:31 PM
tstripling2
Oct 29, 2012 01:35 PM
EDZ82FXR
Jul 27, 2011 10:34 PM
