Charging disaster
Old Jan 9, 2023 | 12:32 PM
dfreemyer's Avatar
dfreemyer
Stage I
Default Charging disaster
I've got an 04 electra glide that I changed the intercom panel on the tank this morning. Have had no issues at all before this, but after swapping, now the ammeter is showing 10v or less while running and engine and battery light are on when driving but not at idle. Did not disconnect anything other than the panel and didn't mess with anything else. Please help...thanks
Old Jan 9, 2023 | 05:30 PM
OkieBill's Avatar
OkieBill
Double-check your work, chances are there’s a minor intermittent short under there.
Old Jan 9, 2023 | 07:22 PM
jimglassford's Avatar
jimglassford
An ammeter measure current. How is it giving you a reading in volts?
Old Jan 9, 2023 | 07:36 PM
Font's Avatar
Font
You are correct. I think he has a voltmeter. My 05 does.
Old Jan 10, 2023 | 07:05 AM
Vernal's Avatar
Vernal
Welcome to the Forum from Utah.
Unplug the new panel and se if the problem goes away. Check the pins on the connector and are you sure the new connector is the same as the old?
Msparrow9868
May 31, 2022 03:21 PM
KINGASOBEE
Mar 11, 2017 09:50 AM
Swftsildedly
Mar 6, 2012 06:44 PM
bobad24
Oct 24, 2007 09:14 PM
Bubba Zanetti
May 26, 2007 05:20 PM
