CB added to the Road Glide
Old Oct 17, 2007 | 07:35 PM
  #101
Jim Dawson's Avatar
Jim Dawson
Default RE: CB added to the Road Glide
Mine seems to work fine with an HD hand mic.
Jim
Old Oct 21, 2007 | 04:35 PM
  #102
sped's Avatar
sped
Well, I gave my cb radio a workout during some riding this weekend and it worked great. Thanks for everyone's advice and help. It is much appreciated.
If someone with a RG is looking to do this, I still have an extra eBay cb unit up for grabs.
Old Dec 17, 2007 | 04:13 PM
  #103
rexjc's Avatar
rexjc
Stage I
I was broke down in the middle of nowhere in Arizona with no phone service (Cell) and the CB Radio save my butt! Otherwise I don't use it at all, but I would not be without one.
ORIGINAL: Shasta69
Friend got one for his Ultra and mentioned the CB was a total waste of money (even though it comes stock on a Ultra). He doesn't use it, never seen him use it, and frankly never seen him listen to music on the road.
-P
Old Dec 21, 2007 | 10:18 AM
  #104
Chicago Spike's Avatar
Chicago Spike
OK, need to order the wire harness and cap and antenna. Do I need to have someone make an extension like cglofland? Or just these 3 items, I have the dash panel, radio and screw set.
Old Feb 24, 2008 | 01:03 PM
  #105
cglofland's Avatar
cglofland
Finally got back to solving my problem of no mic audio. I pinned out the wiring from the tank console plug to the wires at the end before the plug. Found a problem, the schematic shows pin 1 to Black and mic shared (-), pin 4 next to it to be red mic (+), but mine with the ohm meter are reversed, the black and red, hence no audio. Also the shield wire is not connected. Taking every apart now, appears I have a faulty console harness.
Old Feb 24, 2008 | 02:51 PM
  #106
Chicago Spike
ORIGINAL: cglofland
Hmmm, my buddy's brand new Ultra had a bad console harness too. Worked for just a day and then nothing.
Old Feb 24, 2008 | 07:09 PM
  #107
Vegas FLTRI's Avatar
Vegas FLTRI
I had the exact same issue with my console harness bought from chicago harley
ORIGINAL: cglofland
Old Mar 16, 2008 | 11:20 PM
  #108
cglofland's Avatar
cglofland
I mailed off the front sheet from the electrical dia. manual to Harley complaining about the pin out shown in the book and what I got from a dealer, part 77121-98. So will wait to see if they answer.
Old Mar 26, 2008 | 12:00 PM
  #109
mulicki's Avatar
mulicki
Stage III
cglofland,
Did you cut the cable (77121-98) and just add addional wire? Also is the DIN 5 or 7 pins? Where are you getting all of these part numbers from? I have the "big book", "electrical diagnostics", and "shop manual" and all I can say is HD's documentation is very poor with many errors.
Just getting started with my install. Have the CB module and starting to order other parts. So far I understand I need the following for my '07 FLTR:
76312-98 Handheld CB Microphone 76415-06 CB Antenna, Frame 76416-06B CB Advanced Audio 77140-05 Console Chrome 77121-98 Harness - DIN 76266-98 Weather Cover 70169-06 Wiring Harness
Screw kit?
Anything else? or any other works of wisdom? Thanks!
Old Mar 26, 2008 | 12:48 PM
  #110
Chicago Spike
There is also a OEM Part numbers manual you can get. Talk with the guys at Zanotti's HD in Pa. They got me the OEM part numbers manual for a small fee and all the parts so far.
https://www.zanottimotor.com/shopping/partLookUp.html
