You can flush the fluid yourself and then take it to the dealer to cycle the ABS, then if you want to, flush the fluid again but it is not necessary.
My dealer charges 15 min labor for the ABS cycling, and that is on my Trike. Takes more time to get it into the dealer's shop and hook up the digital tech then it does for the actual ABS cycling procedure.
Of course there are those dealers who will say 1 hour minimum shop labor charge on anything, I would be looking for another dealer.
I personally don't see H-D having any responsibility to make the ABS system owner-serviceable. Lots of manufacturers have components or systems which need eventual maintenance but can (typically) only be serviced by a dealer or other qualified shop with necessary software. Anybody who is dead set on servicing their own ABS with a digital tech tool has options; albeit they might be very expensive. Software changes regularly. H-D charges a dealer ruthlessly to keep their software and computers up to date....I have been told that more than once by dealership owners and managers. You or I might buy a $500 tech device only to find it's obsolete on the next bike. Or maybe it only 'marries' to one bike unless you buy another license. We all know how it works, and almost nothing is free.
Personally if a dealer told me $200 I would still pay to have it done every 2 or 3 years. Alternately, I would look into a tech device and weigh that cost vs future savings. In my case I could see no logic in tying up $500 for a tool I'd use once and forget until 2 years later....and then again. Nope...not me. Some struggles are worth it, but with brake & ABS flush happening every couple (or more) years I'm happier to pay my dealer.
if you think about it, $200 over 2 years works out to $.28 per day. i do have the tool, and i 'activate' my abs with it every 5k service. i hope that by doing so, it will keep the valves in good working order. i'm still going to take the bike in to the dealer to have it done when necessary. which in the hot humid south seems to be about every year and a half. one of the steps in the periodic maintenance is to measure the amount of water in the brake fluid. once it is over 3%, time to change it. which in my case, 18 months. for $200, it's still cheap.
Yes. Not that my opinion matters, but I agree with this logic and plan. I may invest in the Daytona Twin Tec some day, but I probably would need to get more use from it than simply activating the ABS module. I do think it's a very good device/tool.
I owned and presided over a vehicle-intensive business for almost 30 years. ABS problems were few, but I had enough opportunities to understand the principles of how they work with hydraulic brakes. Basically: Brake application pressurizes brake fluid and this pressure forces the caliper pistons to move the fraction of an inch needed to engage the brake pad with force. Fluid is not circulating...it's simply under pressure and the amount of fluid movement is minimal. When fluid pressure increases to the point of wheel lockup, the ABS module 'pulses' (modulates rapidly) the fluid pressure to achieve enough relief that lockup is relieved and wheel rotation can happen. In a closed and pressurized brake system there is almost no fluid travel when ABS is activated by over-braking....and that's the simple truth. Riding the bike and locking up the brakes to intentionally engage the ABS module will indeed activate its internal components, but it's not known to be an effective way to actually flush existing brake fluid from the module.
I won't debate the importance of ABS module flushing or digital service for it, as everyone has their own thoughts on the matter. I do think it's important to separate fact from fiction when it comes down to how to properly flush, service and maintain ABS if that's part of your overall maintenance plan.
The only problem is this only works on models up to 2020 without RDRS, have checked with them a couple times and they do not have one for the 2021 and later model.
I use to flush my system out every year using a mighty-vac and never thought the tool was necessary till 3 to 4 years ago when multiple friends had their module lock up. I purchased the twin-tec ll and was reluctant to do it but I service the brake system every spring now with the twin-tec and dont regret it. The ll version has less to offer, but my 2009 is antiquated too.
The Twin-Tec 2 is for pre-canbus bikes and the Twin-Tec 4 is for the canbus bikes.
I almost bought the Twin-Tec 2 for my 2012 bagger many years ago, but held off because I knew I was looking to get a newer Rushmore bagger...
I was pleasantly surprised at the extra stuff the 4 does over the 2.....
But beware..... There was a BCM function that my 4 didn't handle. I called Twin-Tec customer service and spoke to an engineer. He said "those features" had't been added yet. I told him to read their "instructions" because they say you can do it .. He claimed they "jumped the gun" on those features and would pass on the info.... I never saw anything change in their marketing or instructions... To be fair, I haven't checked it for awhile (several years), maybe there's been a software update...
I still like my Twin-Tec 4, but if all those extra BCM and ECM configuring features are really important, I'd pay up for the TechnoResearch Centurion or Diag4Bike tools...
