Draining Battery
Old Apr 13, 2023 | 09:19 PM
MBenbrook's Avatar
MBenbrook
5th Gear
Default Draining Battery
I have a 2007 Street Glide. I was riding one day my gauges started flashing off and on and my headlight started going off and on the radio was flashing off and on and then it died and now it won't start. I thought the voltage regulator was bad replaced it and still nothing it won't even turn over. When I turn the ignition on hit the start button the starter makes a clicking noise kind of like it locks up but it doesn't even turn over. Also my headlights go real dim like it's pulling a lot of juice. Does anybody have any ideas would greatly appreciate it thank you
Old Apr 13, 2023 | 09:23 PM
Screamin beagle's Avatar
Screamin beagle
Have you pulled any codes?
Old Apr 13, 2023 | 10:47 PM
Rounders's Avatar
Rounders
I would focus on battery and charging system. Granted codes are free and easy. But probably waste of time.
I would not have replaced anything based on what I read. Not saying there were not bad,
Charge battery, see if it starts.
Old Apr 13, 2023 | 11:16 PM
MBenbrook's Avatar
MBenbrook
5th Gear
It is throwing the code U1255
Old Apr 13, 2023 | 11:19 PM
MBenbrook's Avatar
MBenbrook
5th Gear
It's throwing the code U1255
Old Apr 14, 2023 | 01:56 AM
Hey Man's Avatar
Hey Man
Time for a new battery.
Old Apr 14, 2023 | 02:13 AM
MBenbrook's Avatar
MBenbrook
5th Gear
That was my next move. Could it be issues with the starter at all?
Old Apr 14, 2023 | 04:28 AM
kojak's Avatar
kojak
Your battery is definitely drained. Could have just failed due to age or you might have had an issue with your charging system prior to this happening that you didn’t notice.
Old Apr 14, 2023 | 05:35 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
U1255 Serial Data Error
The thing is if you take the error code at face value you would end up changing the ECM as that's what generates the serial data.
After charging battery check battery lead connections to the bike and the ground cable for the wiring harness.
Old Apr 14, 2023 | 05:56 AM
Screamin beagle
you're not serious are you? So no one should bother checking codes anymore? Even you said its free and easy so why wouldn't you do that first thing? It only tells you what's wrong and it even tell you the freaking part number for the bad part....yeah you're right...waist of time lol
