Hi all, a newbie Harley owner here, but 30+ years of motorcycling. Just got a 2015 Ultra Classic (flhtk) with a stage 2. I'm hearing a lot of noise/ticking from the engine. I already put in the Rockout inserts and that didn't help. Is the stage 2 just that noisey?
How many miles? Does the ticking change with engine speed? Do you hear it only at idle? Does it go away/appear when you pull in the clutch? All gears?
Can you localize the sound: primary, cylinder head, pushrod base (lifter), cam chest, transmission, clutch?
About 38K miles, ticking goes with engine speed, I hear it all the time, it doesn't go away with the clutch pulled and is in all gears.
I'm fairly certain it's related to the valve train - it gets a little better after it's warmed up, but it's definitely at the top of the engine - under the rocker covers. If I'm at highway speed and really give it the onions, it almost sounds like a hammer.
