Wind Deflectors
Old Oct 1, 2023 | 09:19 PM
USMVMC's Avatar
USMVMC
Default Wind Deflectors
Does anyone have a Road King with the fork mounted wind deflectors on it? How do they work for you? Are they worth the $120? I have a Biltwell Lane Splitter helmet that nearly shakes my head of on the interstate. I don’t have that problem with any other helmets. But I’m hoping the deflectors can fix that.
Old Oct 1, 2023 | 10:01 PM
Screamin beagle's Avatar
Screamin beagle
I have them but only use them when it's in the 40s and below. They definitely create a still pocket of air do keep the wind off of your upper chest and face. I only use them when it's cooler because while I haven't done any scientific testing the engine has to be running a little hotter just because of that pocket of still air that was previously flowing around the motor. Is it actually hotter or im I feeling the engine heat just because of the still air or is actually running hotter? Don't know but I do know they will help your situation because I definitely feel a difference with them on...keeps that cold morning air out of my lovely face lol. Look around here and the other usual places for a used set. I scored mine for 50 bucks.
Old Oct 1, 2023 | 10:37 PM
MyFavRk's Avatar
MyFavRk
They do work , I put them on my Road King a coupe of years ago , the only time I remove them is when it gets above 90* , what a huge difference .
Old Oct 2, 2023 | 12:46 AM
ratpick's Avatar
ratpick
I have the HD fork deflectors and they work very well for me, but I do feel more heat off motor. And as I recall oil temps tended to be a little lower before I installed them--though I don't have an oil cooler, which I suppose might negate much of the difference. I have a 16" recurve windshield I look over and with fork fangs it makes for a very comfortable ride, but I never experienced much buffeting so can't comment as to whether they might alleviate that.
Old Oct 2, 2023 | 12:51 AM
USMVMC's Avatar
USMVMC
Thanks thats just what I wanted to know. I’ll order some this week.
Old Oct 2, 2023 | 12:56 AM
USMVMC's Avatar
USMVMC
Thanks for the reply. I am purchasing the HD brand deflectors also. I am probably gonna purchase a shorter recurve windshield from Long Ride shields also. So I am glad to hear they work also. I had one on my Ultra Classic but wasn’t sure how well they worked with a full sized windshield.
Old Oct 2, 2023 | 07:09 AM
GalvTexGuy's Avatar
GalvTexGuy
OP, you are probably aware of this, but if you leave the visor in the up position, it will act like a sail and catch wind going over the top of the helmet causing extreme buffeting. Just an FYI.
Old Oct 2, 2023 | 08:31 AM
T^2's Avatar
T^2
Lots of factors involved here. The helmet was already mentioned - different helmets perform differently behind a windshield.
Based on my experience on a '18 Heritage, fangs work, but almost too well. Fangs greatly reduce the air coming up from below around the tank. However, fangs have a downside. They greatly increase the heat in the rider pocket (all that cooling air for the rider is lost). The right leg and crotch area also get quite toasty. Riding with them installed on a hot summer's day is a no-go in my book. Do fangs impact engine temps? I haven't seen anything conclusive on this issue. My rudimentary testing suggested they might. That's another reason that I uninstalled them.
One thing that made a significant difference for me was the vent.
https://www.clearviewshields.com/abo...hield-venting/
The idea of the vent is to relieve the pressure differential that develops behind the windshield. Venting theoretically smooths the airflow over the windshield and reduce turbulence created by the air abruptly trying to fill in behind the screen. The one I have on my ClearVeiw shield has multiple opening positions. Setting it to the right one is key (for me position 2 from fully closed). Setting the vent to any other position and I'll experience a huge difference when wearing my full-face.
The vent works well with my full-face. However, I still get just a tinge of buffeting if speed gets high enough (60mph+). The buffeting is ever so slight. Removing my face shield tends to eliminate that remaining tid-bit of buffeting. If I was planning on doing a lot of highway miles, I might remove the face shield and a put on the riding glasses. I have no problem with my half helmet - at least from buffeting (again with the vent in position 2). Wind noise from the helmet straps is another matter.
Anyway... my 2 cents.
Old Oct 2, 2023 | 08:42 AM
USMVMC's Avatar
USMVMC
Yeah I never ride with the shield in the up position. It so weird that it’s just this helmet. I have two other full face helmets. A Bell Bullitt and a Biltwell Gringo plus my main helmet which is one of those super light and small half helmets and none of them do this.
Old Oct 2, 2023 | 08:46 AM
USMVMC's Avatar
USMVMC
Never thought of the engine heat. I may just wait on the fork deflectors and put my money into one of Long Ride Shields recurve windshield. Won’t help my helmet issue but since it’s just that one helmet I think I can live without them for the time being. Thanks for the help
