Lower vent adjustment
Old Aug 26, 2007 | 07:08 PM
PDDGM's Avatar
PDDGM
Default Lower vent adjustment
Has anyone had the problem with the vents blowing closed on the Ultra lowers? The right one on my 2005 will not stay
open. I have tightened the bolt, to the point I am afraid of breaking something. Any ideas?
Joe
Old Aug 26, 2007 | 07:15 PM
mlhampton13's Avatar
mlhampton13
Default RE: Lower vent adjustment
When I had my lowers on I found that I was kicking the right vent closed with my big foot.
Old Aug 26, 2007 | 09:26 PM
gdbro4's Avatar
gdbro4
On my 05 they tightened bolt. But on my 07, they don't know how to fix the problem, so my left one closes after about 2-3 miles at 50+.
Old Aug 27, 2007 | 04:44 AM
BirchwhiteHD's Avatar
BirchwhiteHD
I just installed vented lowers on my bike,i noticed my left one will closed one click,right one seems fine,i havent tightened anything yet,but im going to now, thought it was just mine,good question. i'll have to keep an eye on mine
Old Aug 27, 2007 | 06:04 AM
pfd161's Avatar
pfd161
I just took them out for the summer...5 min job. Love the increased airflow too.
Dennis
Old Aug 27, 2007 | 06:15 AM
kgjl's Avatar
kgjl
I removed the vent. I like it. Seems cooler. Keeps more rain off my legs than nolower at all.
Old Aug 27, 2007 | 07:13 AM
PDDGM's Avatar
PDDGM
Ok, thanks for the input. I went out last evening and got my socket set out, and tightened it up until it stayed open and took a some force to close it. I figured what the hell it I broke it I would just take the vent part out. But it seems to be better, haven't ridden it yet, but will today...
Joe
Old Aug 27, 2007 | 12:02 PM
Copout's Avatar
Copout
6th Gear
I'm having the same problem with my '06. Have not come up with a solution, yet. Thought about maybe some additional washers.
Old Aug 27, 2007 | 04:58 PM
luckystars5's Avatar
luckystars5
I had this problem on my 06 Ultra.
I put black wire ties around the top of the vent and routed the ends into the glove box on the lowers. On end over top of glove box (inside lower) and the other end up through the bottom near the front. Zip the two ends together until the loop is snug, snip off the excess and your done. You can barely see the wire tie at the top of the lower vent and it does not clutter up the glove box. Takes 5-10 minutes and you can zip ties together to make a long tie if you only have short ones.
When winter comes, snip the wire tie and throw it away.
Jjohnson312
Jul 9, 2018 08:48 PM
rob0225
Jan 7, 2013 10:22 PM
C908
Nov 5, 2010 10:22 PM
GGC
Apr 15, 2007 02:01 PM
Fandango6
Aug 12, 2006 11:41 AM
