First post: New Harley owner questions
The wife needs a back rest which also means docking hardware but my question is: If i want to add a tour pack at some point, will that use the same docking hardware as the sissy bar?
I think the answer is yes, but the tour pack will need special mounting hardware to fit the docking hardware on the bike, right?
I'm pretty new to Harleys and stuff but I think I got that right......let me know.
thank you.
My new ride.
thank you.
My new ride.
If you add a tour pak later, youll simply remove the detachable passenger backrest from the docking hardware, and add the tour pak in its place. It would be mounted on a quick detach (detachables) tour pak rack/base, to the docking hardware.
Very typical and routine.
thank you.
My new ride.
You will need the 4-point docking hardware, sissy bar, and sissy bar pad.
and here you can see the tourpack I added to my bike and everything that is needed: Amazon TCMT Chopped Tour Pack - Harley Davidson Forums (hdforums.com)
You will need the tourpack and removable tourpack mount.
I tell a lot of new comers to the forum to get: Factory Service manual and the Parts manual. Take to an office supply store and have them put a spiral binder in place of the glued binder. That will let the manuals lay flat on your bench. Get a three ring binder and record all your maintenance, repairs, accessories, etc. This will be a great reminder of what was done when. And great material to pass along to the new owner should you sell and upgrade. Also know how large your fuel tank is, a rough idea of your range per tank, and record your fuel usage. I have an app called Simply Auto that I record all my fuel used. I use the odometer and use the fuel gage as reference only. I reset the odometer to zero on fill ups, and I know I can safely get 200 miles on a tank on around town riding, and upwards of 230+ on trips.
