Cracked touch screen
Old Jan 26, 2024 | 07:29 AM
  #91
roussfam's Avatar
roussfam
So does the screen crack if you over pressurize the system or under pressurize??
Old Jan 26, 2024 | 07:33 AM
  #92
Notgrownup's Avatar
Notgrownup
Only if you are wearing gloves.
Old Jan 26, 2024 | 07:44 AM
  #93
dolah03051's Avatar
dolah03051
5th Gear
i did wash it before i out it into the shed. the shed is not water tight however it does not leak on the bike. i do believe there was water around the screen which caused the spidering thiis is an issue for harley becuse the water should not build up.
Old Jan 26, 2024 | 07:52 AM
  #94
dolah03051's Avatar
dolah03051
5th Gear
no it is pretty secure maybe a mouse
Old Jan 26, 2024 | 08:01 AM
  #95
dolah03051's Avatar
dolah03051
5th Gear
i did not see the rest of your post which o hoped would help me better understand
  #96
roussfam's Avatar
roussfam
As mentioned before, maybe try contacting the manufacturer? See if they can help you out with a repair? All kidding aside, keep us posted, hope it works out.
Old Jan 26, 2024 | 08:02 AM
  #97
dolah03051's Avatar
dolah03051
5th Gear
no body sells them separate from the radio
  #98
roussfam's Avatar
roussfam
But what about the actual manufacturer?
Old Jan 26, 2024 | 08:06 AM
  #99
dolah03051's Avatar
dolah03051
5th Gear
not sure of the manufacture but i did find a company that repairs them for harley under warranty i will pursue this
Old Jan 26, 2024 | 08:15 AM
  #100
Oko's Avatar
Oko
OP If nothing comes of your chase for a warranty claim, I'd suggest buying a used unit. Someone can correct me if I'm wrong, but I believe they are plug and play.
If you put in an insurance claim you'll be out the deductable. I see them on eBay for a G note plus.
Just offering it up as a suggestion......
https://www.ebay.com/itm/22596492146...3ABFBMxu_v4ahj
