SG Outer Fairing
Old Mar 14, 2024 | 02:15 PM
steelpony16's Avatar
steelpony16
Default SG Outer Fairing
Hey All, For some reason I can't get my outer fairing to pull in all the way on the top left side to the gasket?
I have removed the outer fairing on 3 different streetglides several times with no problems at all.
This streetglide I removed the fairing mirrors and put HD mirror hole plugs on.
Put the fairing back on and can't get it to seal against the gasket, I can slide a business card thru the outer fairing and rubber gasket (Only on the top clutch side)
Any ideas?
Old Mar 14, 2024 | 04:46 PM
NoRegerts's Avatar
NoRegerts
My first thought is, something is pinched, or in the way. A wire where you aren't expecting it to be, or maybe a bung has come misaligned.
Old Mar 14, 2024 | 06:10 PM
Jshopes's Avatar
Jshopes
i would check the alignment tabs, pull off and remount if it were my ultra, but im not sure a street glide would be the same
Old Mar 15, 2024 | 08:46 AM
NoRegerts's Avatar
NoRegerts
If they are the same generation, the parts are the same.
Old Mar 15, 2024 | 09:06 AM
Jshopes's Avatar
Jshopes
i was being facetious since the op just saud streetglide.
Old Mar 15, 2024 | 12:18 PM
NoRegerts's Avatar
NoRegerts
Old Mar 16, 2024 | 08:46 AM
benscratchin's Avatar
benscratchin
I've had my fairing off, and on a couple of times. (2012 FLHX) for speaker upgrades, Amp install, etc. It can be a bit tricky on installation if anything underneath the Fairing has been disturbed.
I'd try removing the Fairing, look at the underside to see if there is any obvious rubbing marks on the Fairing. Inspect all the wiring etc. to see if everything is tucked into place as it should be. When you reinstall the Fairing, put all the screws in finger tight only. Then start tightening the screws at the top left first (where your gap problem was).
Good luck.
Old Apr 2, 2024 | 02:24 PM
steelpony16
Good luck.
Okay Fellas, I've tried everything, it will not pull together completely.
I started to think about the inner fairing. Is it possible when they did the handlebars that the inner fairing was seated a little bit wrong?
In other words, is there something i can loosen to move it?
Old Apr 2, 2024 | 08:23 PM
Jshopes's Avatar
Jshopes
on my 14 the yaffe bars i had interfered with the bottom of the fairing by the ignition switch.
Old Apr 3, 2024 | 08:05 AM
steelpony16
Well, after talking to a buddy, his 2018 is the same way on the clutch side as well, his gap is even worse than mine.
I spoke with a local HD Service Manager yesterday and he walked around the showroom floor and tested some brand new bikes and used bikes,
some were good and some were bad (All on clutch side), he used a piece of paper to slide in.......
Going to try and find like a 1/16" diameter piece of rubber with a durometer of 20 to 40...
Unless someone has a better idea?
