2005 road glide headlight not working
Old Apr 27, 2024 | 02:45 PM
sneakythack's Avatar
sneakythack
4th Gear
Default 2005 road glide headlight not working
So I just bought this bike and got it home. My headlight won’t come on. High beam light doesn’t come on either. Installed new handlebars and all controls work as far as cruise and radio. I’ve checked all my grounds and the fuse to make sure it isn’t blown. All lights work just not my head light. Also throwing code p0563.cleared the codes but haven’t rode it again to see if they pop up again. Anyone have any ideas on what it could be
Old Apr 27, 2024 | 07:15 PM
btsom's Avatar
btsom
Have you checked the plug with a volt meter to see if the power is making it that far? Since both filaments are not working, I would suspect the ground wire is not grounded.
Old Apr 29, 2024 | 11:04 AM
Architect's Avatar
Architect
Remove fairing and headlights. Check for power at headlight plug. No power? Follow the wire back into the bike, it either goes to the hand controls or ignition switch. When you find the other end, does it have power? If yes, the problem is in between. If no, keep chasing it back. Wiring diagrams available on line. Only you can chase an electrical gremlins, no silver bullet answers to be found, good luck.
Old Apr 29, 2024 | 11:19 AM
memphisharley's Avatar
memphisharley
was the light working when you purchased it. if you haven't...make sure it is plugged up.
Old Apr 29, 2024 | 11:29 AM
Tom H's Avatar
Tom H
Could the light be bad? Not likely hi and lo would both go out, but might be worth checking as well as the previous suggestions.
Good luck,
Tom
AtticusFinch
Oct 2, 2023 09:07 PM
NDanecker
Aug 5, 2020 11:42 AM
glcashx2
Jul 24, 2017 07:26 PM
Hnter1018
Electrical/Lighting/Alarm
Mar 19, 2016 06:40 AM
JSW
Mar 10, 2007 07:28 PM
