Excessive rotation in main shift?
Old May 6, 2024 | 08:36 AM
TexasTTB's Avatar
TexasTTB
1st Gear
Default Excessive rotation in main shift?
I have a 2010 ultra classic CVO that makes a heck of noise when I pull up and stop coming from the primary. If you look at the video when I rotate the main shaft back-and-forth it is that noise but quite a bit louder.
I replaced the compensator a year ago, thinking that was the issue. Chain tension is correct.
does anyone have any ideals?
File Type: mov
Old May 6, 2024 | 09:08 AM
eighteight's Avatar
eighteight
I would suspect the inner primary bearing
Old May 6, 2024 | 09:29 AM
TexasTTB's Avatar
TexasTTB
1st Gear
Default bearing.
I put an indicator on the shaft. There is no side to side play on the bearing.
Old May 6, 2024 | 10:42 AM
MotoJockey's Avatar
MotoJockey
Normal from what I've been told. Shift the tranny into higher gears and back down to watch the rotation degrees change......
Old May 6, 2024 | 10:54 AM
Ohio HD's Avatar
Ohio HD
The backlash in the transmission shaft is 100% normal. It's simply the movement that exist between rotation forward and back ward in the gears.
When you hear this are you still in gear? Are you downshifting as you slow down? Or have the clutch pulled in? Exactly when does the sound occur, and does it also make the noise slowing down with the clutch pulled in?
Old May 6, 2024 | 11:31 AM
Screamin beagle's Avatar
Screamin beagle
Does the noise go away when you pull in the clutch? Yes...inner primary bearing. Can you feel extra vibration while riding in any gear any engine speed? Main drive gear bearing may be bad. Sit on the bike with it not running kick stand up and slowly roll it backwards and forwards with it in neutral and the clutch pulled in. Can you "feel" any roughness or hear any crunchy type noises?
Old May 13, 2024 | 02:55 PM
TexasTTB's Avatar
TexasTTB
1st Gear
I hear it when I come to a stop and have the clutch pulled in like at a red light.It will also make the noise sitting in neutral while idling.
Old May 13, 2024 | 03:19 PM
Ohio HD's Avatar
Ohio HD
Could be the inner primary bearing and race going bad.
Lunchboxx
May 6, 2024 11:17 AM
Voldemort
Aug 17, 2013 07:03 AM
Ndoggct
Jun 16, 2013 07:20 PM
redneck47441
Sep 14, 2012 03:00 AM
abrown2669
Screamin Eagle CVO Models
Jul 9, 2010 03:56 PM
