03 Road King Stator Rotor Question
Old Jun 12, 2024 | 09:01 PM
budha9109's Avatar
budha9109
Originally Posted by Dano523
Rotor is fine, and if you know anyone with a lathe, can make a quick face pass to clean that up.
Spacer Washer needs to be replaced
And don't forget to use red loctite when you reinstall the comp nut.
Comp teeth on the sprockets are cooked, ramps and tip are worn down that was causing problems as well on comp over just worn washer, and will guess that the teeth on the clutch basket teeth are about the sames worn shape as well.
So on that note,
would be looking for good used Comp set with springs, but without rotor, and outer clutch basket if the teeth are the same as on the old comps teeth.
Note, check inner clutch hub back side spines for any damage, and if you do find that some of the spines at the end are cracked off, may as well just get entire clutch basket with bearing assembly. And if you need to replace the basket bearing since will bank that is got pounded to hell as well, may as just pick up complete clutch basket assembly from the start.
Man, I wasn't wanting to hear more parts need replaced lol. But thank you for the input. I'm just worried about the rotor.. The backside has some what looks like to be wear also and the grooves that slide onto the shaft look worn also.
Just curious, but what about the comp teeth make you say that they're toast? I genuinely just want to know what to be looking for. Thanks!
Old Jun 12, 2024 | 09:03 PM
budha9109's Avatar
budha9109
Also on the comp ramps.. What makes them worn down? I figured the smoothness would just be from normal wear/use
Old Jun 12, 2024 | 09:46 PM
Max Headflow's Avatar
Max Headflow
The comp is fine. The rotor needs replacing. You need to trim 0.060" off the comp nut. If the rotor spines were good you wouldn't need to face the rotor surface.. Might stone it a little but it would bite into the comp a little better.
budha9109
Electrical/Lighting/Alarm
15
Jun 13, 2024 12:05 PM
sbrmike
Shovelhead
Dec 8, 2021 11:38 AM
Bagger G
Apr 24, 2018 07:03 PM
cfd37buckeye
Aug 9, 2011 06:07 AM
EVOrider
Jan 16, 2008 03:33 PM
