Stage 2 alter friction zone power?
I am looking to do a basic stage 1 and then stage 2 with just cams. Once tuned will this alter the bikes friction zone power?
To be more clear, currently I have a 2023 RKS. When I release the clutch the bike begins to move and obviously I add throttle to continue. My other bike is a 2016 dyna and it on the other hand doesnt do much with just clutch release, throttle is needed to not stall.
I love how the RKS is and I am concerned if I do a stage 2 I may alter things and turn it into how the Dyna is. (I dont know if the Dyna has a stage 2 or not as it was purchased how it is. But it sure sounds like it)
so again sorry for the dumb question. I want a better sounding bike with a bit more power but I dont want to lose my power/control in friction zone.
hopefully this makes sense.
Granted I have the old non hydraulic clutch but I really saw no difference after my stage 2 install. I haven’t heard anyone with a hydraulic clutch mention issues or differences either. Depending on your cam you have more available torque at given rpm’s so may require a slight learning curve. I have a torque cam (Andrews48) and find improved clutch response when having* to feather the clutch in situations that warrant it.
not sure if that helps but I don’t think you have anything to worry about.
To be more clear, currently I have a 2023 RKS. When I release the clutch the bike begins to move and obviously I add throttle to continue. My other bike is a 2016 dyna and it on the other hand doesn’t do much with just clutch release, throttle is needed to not stall.
I love how the RKS is and I am concerned if I do a stage 2 I may alter things and turn it into how the Dyna is. (I don’t know if the Dyna has a stage 2 or not as it was purchased how it is. But it sure sounds like it)
so again sorry for the dumb question. I want a better sounding bike with a bit more power but I don’t want to lose my power/control
If you have a cable clutch you may need to adjust it again.
I have a 2019 107 M8 with Harley Stage II (torque cam). When I release the clutch slowly without throttle, the bike is happy to move forward. This is useful when backing into a parking spot and making small adjustments. Idle forward a few feet, move the bars, back up again, etc.
When I installed the cam I felt I had more and a more even application fo torque in the friction zone
