Found a piston crack
Old Jul 26, 2024 | 06:08 PM
pyuchem's Avatar
pyuchem
Originally Posted by Dano523
Would do two search,
The first is cylinder detonation problems from running too lean to first understand that and why it can crack the piston,
Then the second search is Harley tuning too lean to meet EPA standards that cause the detonation problems to begin with.
Granted that problem could have been induced by clogged fuel filter, not enough pressure on the rail, or clogged fuel injections to cause the lean problem, but with Harley tuning AFR well above 14.7 to start with, main reason for most detonation problems in the first place.
And going to guess, motor is still on Harley stock tune, way too lean to start with (fuel is cooling).
Yup still stock. Do you really think keeping it stock caused this issue. I really didn't feel like I needed a tune/stage I done. For me 103 is plenty powerful. Plus I do not ride aggressive except on windy roads, then I scrape floorboards.
I guess going stage I would have been helpful. On the other hand I like how stock bike is quiet, I barely hear my bike or exhaust when riding.
Old Jul 26, 2024 | 07:10 PM
NorthWestern's Avatar
NorthWestern
That is just wrong.
Old Jul 26, 2024 | 07:38 PM
Max Headflow's Avatar
Max Headflow
The problem is typically not HD tho in the case of early CVO 110s it is.. It's more of an issue with changing the intake and/or exhaust an not re-tuning. Running 14.7 is fine for cruise. Lugging the motor only exacerbates things..
Old Jul 27, 2024 | 07:36 AM
Lonewolf176's Avatar
Lonewolf176
(fuel is cooling).
Old wives tale
Old Jul 27, 2024 | 08:16 AM
Max Headflow
Originally Posted by Lonewolf176
Old wives tale
It does seem to help but it's only a few degrees.. I recently leaned out the whole map on a my tmaxed 107 EGC 1/2 point AFR. Picked up about 3-5 MPG but the oil temps went up a few degrees..
Old Jul 27, 2024 | 08:39 AM
Rounders's Avatar
Rounders
Originally Posted by flh canuck
First thing I would do is check pinion runout to make sure the crank is still healthy. If crank is good, check out the 107" kit from Fuel Moto. It runs about $1400 and comes with everything you see in the picture and would really wake up that engine of yours. Cheaper than oem in the long run and probably better quality components. Of course you also have to budget for a dyno tune following install but as already mentioned, you might as well make some lemonade while you have it apart!
He already has a 103, I believe. Is 4" worth it? Cams and porting. Spec cylinders are still in spec or bore ten over. I paid $250 to bore 7", its less if 10 over.
You starting chasing every hp, plan for darkhorse next year and tranny too, expecially on an older bike.
Old Jul 27, 2024 | 08:43 AM
Mongo1958's Avatar
Mongo1958
Stock. No pics but I was able to see when he had camera in there.
Time for a big bore kit.
Old Jul 27, 2024 | 12:11 PM
94 ultra's Avatar
94 ultra
107 or 110 big bore fuel moto
May as well
Same cost
You will have to buy a Power Vision which you will not regret
Old Jul 27, 2024 | 12:21 PM
Max Headflow
May as well
Same cost
Haven't looked at the price but it seems to me that you can save money on a 107 because you can reuse your old cylinders..
Old Jul 27, 2024 | 02:39 PM
Lonewolf176
Unless you see how good a TTS is
