Which Loctite?
Old Sep 3, 2007 | 11:45 AM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: Which Loctite?
BLUE
Old Sep 3, 2007 | 02:37 PM
Bulldawg's Avatar
Bulldawg
I'm disappointed it took 6 replys for JB Weld to surface.
Old Sep 4, 2007 | 05:26 PM
rome304's Avatar
rome304
blue.
Old Sep 4, 2007 | 06:59 PM
tallboy56's Avatar
tallboy56
Dude, I've been selling Loctite for nearly thirty years and would NEVER use red unless the fastener is one inch or larger. These products really all do the same thing...they cure in the unexposed threads closing off the inherent clearance between mating parts. Blue (242) is the best "everyday" threadlocker to use, even if you are sealing a large fastener. The only way to remove the red/high strength threadlockers is to heat to about 450 degrees F or break the fastener. A couple of other things to keep in mind: these products have a shelf life...if it's been in your buddy's tool box for ten years, it probably won't work. Also, even if it is new product, shake it thoroughly. There are newer products too such as stick threadlockers which don't let the ingredients separate and they don't run all over the place. They have a gel threadlocker which is only available at certain distributors which is pretty cool as well. Ask your local Loctite distributor about these products to get the best advice for use. Loctite has a lot of excellent stuff...IF used properly. I would be happy to answer any questions also...hope this helps.
Old Sep 4, 2007 | 07:19 PM
bay13's Avatar
bay13
Blue
Old Sep 4, 2007 | 07:41 PM
chipishere's Avatar
chipishere
Wish this post would have come up BEFORE I put red on my front shift lever bolt. Friggin thing is loose again and I can not get the bolt out.
jon loder
General Topics/Tech Tips
42
Feb 20, 2017 06:23 PM
Thumper09
Jul 10, 2014 07:05 AM
inswva
Sep 9, 2011 11:15 AM
kingofsand21
Mar 11, 2010 10:06 AM
Twohulabears
Dec 23, 2005 08:47 PM
