2000 FLHTCUI starter.....
Old Feb 13, 2025 | 11:24 AM
ScottinAZ's Avatar
ScottinAZ
Default 2000 FLHTCUI starter.....
I think the starter took a wet **** on my bike.... Its been sitting with a dead battery for a couple of months. Put in a fresh battery and all I get is a click from the solenoid... Pulled plugs, and motor is NOT locked up, but all I still get is a click from the starter.... I changed it a few years ago, but its been a minute. IIRC, I have to pull the primary cover to remove the jackshaft, but I dont remember having to pull the outer cover where the dipstick is.... Can anyone refresh my memory on that, It has four bolts, two of which are a PITA to get to, behind the exhaust.... After pulling the jackshaft is there enough wiggle to do the job, or am I phucked? I have the old starter which I took off, turns out it really was a shitty battery that time.... I plan on sticking it back in for now....
Old Feb 13, 2025 | 06:19 PM
Rounders's Avatar
Rounders
I'd tell ya, but I don't want to muck your thread up. So just read the manual.
Old Feb 13, 2025 | 07:48 PM
JimL_15 Electra Glide's Avatar
Try tapping on the solenoid and see if it will work. I use that method on many an auto. Also make sure your battery connections are clean and tight.
Old Feb 13, 2025 | 08:51 PM
ScottinAZ's Avatar
ScottinAZ
yep, that’s a no bueno. Treating it like a Chevy didn’t help…. I’ll yank the primary cover probably later this weekend. Rain forecasted, and other **** I gotta get done……
Old Feb 14, 2025 | 04:03 PM
xcbullet's Avatar
xcbullet
The worst is having to open up primary but you can get the starter out after that, it is tight though and I think you have to take the chrome cover of starter to be able to wiggle it out. Also the mount for the cross over clamp
that starter most likely needs new contacts . I have a extra starter with new contacts waiting to go in when ever i have the primary open
Old Feb 14, 2025 | 04:17 PM
deadhawg's Avatar
deadhawg
It's more likely the solenoid, not the starter itself. common problem on older bikes. google "the click of dread" for lots of info on the issue and how to fix it.
Old Feb 14, 2025 | 04:59 PM
ScottinAZ's Avatar
ScottinAZ
I was thinking the same. Solenoid contacts, or possibly brushes…. As long as I can get the bastard out without pulling the dipstick cover, it won’t be too bad….
Old Feb 14, 2025 | 07:11 PM
Max Headflow's Avatar
Max Headflow
Measure the voltage at the starter when the button is pressed. Needs to be above 10V.
Pull the skinny wire to the solenoid and jumper from the blade on the connector to the 12v battery terminal on the solenoid.
No bueno on cranking, measure the voltage coming out of the solenoid.
Wayne Hand
May 16, 2022 08:14 PM
fxr289
Apr 18, 2020 07:23 PM
thirsty
EVO
14
May 16, 2019 11:03 AM
Mar 26, 2012 06:54 PM
bwanas
Oct 22, 2009 09:21 PM
