LED low Beam help needed
Old Jun 29, 2025 | 01:58 PM
nashspu's Avatar
nashspu
Default LED low Beam help needed
I have a 2019 Street Glide Special and the led low beam is out. I tried getting one from the dealership and they sent me a halogen bulb even though I emailed them these pictures. trying to find one on the internet and having no luck whatsover. Can any of you help me find some to replace this bulb? I will even buy the high and low beams as a set so they match just to get it fixed. it has the wires and the extra little boxes attached to it for the led conversion. I did not take a picture of the whole thing when it was apart bcuz I didn't think this would be a hard part to find. thak you for your help
Old Jun 29, 2025 | 03:22 PM
Ultra103's Avatar
Ultra103
That looks aftermarket. How about a picture of the light itself front and back?
Old Jun 29, 2025 | 04:37 PM
chopper_man's Avatar
chopper_man
That's not stock. Previous owner swapped out the stock halogens for LED's.
Old Jun 29, 2025 | 07:20 PM
nashspu's Avatar
nashspu
I took more pictures of the bulb itself. It has 3 sides and a fan built in to the base. I realize it is aftermarket but can't find it yet. I have seen fanless h11 led bulbs, the lumens and stuff don't match exactly but would probably work. Would like to keep both bulbs matching brandwose obviously so they have the same light profile.
Old Jun 29, 2025 | 07:42 PM
J Cagg's Avatar
J Cagg
Those were on Amazon a few years ago.
I would recommend replacing with a full LED unit (i run Sunpie and haven't had a problem). Or you could go to any autoparts place and get and individual or pair of replacements.
Thr technology improved quickly since those were out. Fans are no longer needed to dissipate the excess heat of the resistor pulling the voltage down to the LED requirements.
But, then again, I could totally be full of **** and have no idea to which I speak off. 😆
Old Jun 29, 2025 | 09:38 PM
GalvTexGuy's Avatar
GalvTexGuy
They ain’t cheap!
https://www.westendmotorsports.com/r...nd-road-kings/
Old Jun 30, 2025 | 06:53 AM
Buelligan666's Avatar
Buelligan666
Those LED replacement bulbs are garbage. They don't meet DOT requirements. They throw a lot of glare and blind incoming traffic. Buy a proper DOT approved LED headlight assembly.
Old Jun 30, 2025 | 07:19 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Go with the Sunpie units and you will be better off and have better light.
Old Jun 30, 2025 | 07:49 AM
Ultra103's Avatar
Ultra103
I'll third Sunpie lights. I've run them on 3 bikes now and love them just as much as day 1.
Old Jul 1, 2025 | 04:50 PM
J Cagg's Avatar
J Cagg
Originally Posted by GalvTexGuy
You can catch the full set up from Sunpie (headlight and spots) for about the same or less than what you linked! Wow!
