ABS sensor continues to cause issues
Old Feb 6, 2026 | 03:51 PM
labou1's Avatar
labou1
Angry ABS sensor continues to cause issues
I have a 2022 HD Street Glid FXDL and am having a problem with my ABS sensor. It seems as if every time I use the front or back break really hard OR even put the front wheel into my wheel chock, my check engine light comes on. When I go to Diag. the EMC shows an issue and when I follow through and come to ABS, it shows a fault and I have to remove it before I can do anything else. Is there ANY way to bypass the ABS system so this does not happen again. At different times, when this happens, the bike will start but I have NO throttle response.
Old Feb 6, 2026 | 04:02 PM
2017M8's Avatar
2017M8
What work has been done to the bike as of late. What are the codes.
Old Feb 6, 2026 | 04:30 PM
DeeRoe's Avatar
DeeRoe
Just curious.....
Since it's a '22, when was the last time you did a brake flush, where the ABS is cycled to flush the ABS module?
Old Feb 7, 2026 | 01:29 PM
labou1's Avatar
labou1
I have done a few things like lowering 1 ˝” and raising handlebars, Was very careful making connections and testing wires. ECM-P1100h, ABS- 1100h, BCM-62206h. This doesn’t happen frequently only now and then but it is so frustrating. I went back in this morning and double checked what I thought it may be and also checked fluid levels.
Old Feb 7, 2026 | 01:39 PM
GalvTexGuy's Avatar
GalvTexGuy
Are you getting these codes through the bike or are you reading them on a PowerVision or some other tuner? The reason I ask is the codes you show are historical, noted by the “h” at the end. Another member recently posted about a code that wouldn’t clear on his PowerVision, but when he cleared it on the bike it went away and didn’t come back.
Old Feb 7, 2026 | 03:36 PM
labou1's Avatar
labou1
Gettign these code directly through the bike and when I clear them, they are cleared but do come back now and then at which time I have to clear them again.
Old Feb 7, 2026 | 04:11 PM
rideonva's Avatar
rideonva
How did you raise handlebars - maybe there's strain in wiring ? B2206 is run/stop switch is short or open, C1100 - traction control failure. Maybe when you turn the bars connectors momentarily loose connections, which brings your codes and ABS light.
Old Feb 7, 2026 | 05:12 PM
GalvTexGuy's Avatar
GalvTexGuy
When you raised the bars, do you mean you replaced the bars because there is no way to raise bars on a Street Glide.
Anyway, did these codes start showing up after whatever you did with the bars?
Old Feb 7, 2026 | 05:28 PM
labou1's Avatar
labou1
Default 13" x 1 1/4" Chubbys
I installed Wild 1 14"Bagger hooked Chubbys, Prewired and I have checked anything that could be an issue here and could not find anything.
Old Feb 7, 2026 | 05:38 PM
GalvTexGuy's Avatar
GalvTexGuy
Did this issue start after the bars were installed?
