Steering head adjustment question
Old Sep 18, 2007 | 08:51 PM
Streetrunner's Avatar
Streetrunner
Default Steering head adjustment question
My dealer tells me that they check the steering head by making the handle bars swing back and forth x amount of times. They say they do this with the fairing (SG) attached. I thought I read somewhere that this test is to be performed with the entire fairing removed.
Does anyone know how to properly perform this test?
Old Sep 18, 2007 | 09:13 PM
voodoodrug's Avatar
voodoodrug
Default RE: Steering head adjustment question
Is that the test where you put bike on a lift and push steering in one direction and it should bounce back in a pattern of some sort? if doesnt then steering adjustment is needed or something like that?
Old Sep 18, 2007 | 09:14 PM
Streetrunner
ORIGINAL: voodoodrug
yes, that is the test.
Old Sep 18, 2007 | 09:21 PM
voodoodrug's Avatar
voodoodrug
ok ive seen it done and they did not remove fairing.
Old Sep 18, 2007 | 09:23 PM
streeter's Avatar
streeter
Streetrunner, this is the test you are looking for:
1) Wheels off the ground andon a level surface.
2)Turnbars to the left steering stop and thenlet go.
3) the adjustment is correct if the wheel swings full right, then left and back to the right.
Note: the second swing to the left will not go to the stop and the third swing back to the right will be a partial swing stoppping at random. Less than 3 swings = too tight and more than 3 swings = too loose.
Streeter
07 FLHX
Old Sep 18, 2007 | 09:27 PM
Streetrunner
ORIGINAL: streeter
Streeter
07 FLHX
Thanks Streeter but is this done with the fairing attached to the bike? The dealer says they think so but I'm thinking I read somewhere that the fairing should be removed. I don't have a whole lot of confidence in dealers. I feel better relying on the responses from this forum.
Old Sep 18, 2007 | 09:28 PM
streeter's Avatar
streeter
You are correct, the fairing must remain on as well the bike must be stock form with no accessories bolted on that would affect the balance, weight positioning etc.
Streeter
07 FLHX
Old Sep 18, 2007 | 09:34 PM
streeter's Avatar
streeter
ORIGINAL: Streetrunner
ORIGINAL: streeter
Streeter
07 FLHX
Yes it will stay on. Keep in mind this a static test to set-up steering response. Any increase (removing fairing) or decrease in weight to the front end will changethe swing momentum resulting in an inaccurate adjustment.
martin10
General Topics/Tech Tips
Mar 27, 2017 09:54 PM
Robtarra39
Jun 2, 2012 01:54 PM
BLK08ROCKERC
Apr 15, 2011 04:45 AM
commander112
Jun 21, 2010 09:36 AM
Fast Eddie
Feb 1, 2007 07:15 PM
