HELP loading SERT map
Old Sep 21, 2007 | 03:48 PM
dawg's Avatar
dawg
Default HELP loading SERT map
I borrowed cables for the SERT to my laptop, but my laptop didn't have a serial port so I bought an adapter to use the USB port. I cannot get the SERT to recognize the USB port and I have chosen the right port from the com port menu and all. Does this not allow USB ports? any help?
Old Sep 21, 2007 | 04:25 PM
gunrunner's Avatar
gunrunner
Default RE: HELP loading SERT map
I had to hook it all up, computer,adapter,sert cable,sert then to plug on bike and have switch turned on and make sure your run switch is in run position.
Old Sep 21, 2007 | 04:32 PM
dawg's Avatar
dawg
I went to a bud's house and used his regular computer with a serial port and got the same message "cannot communicate with ECM" I didn't have the run switch in the run position though, I will go try that. I'll be back if that doesn't work....stay tuned
Old Sep 21, 2007 | 04:41 PM
dawg's Avatar
dawg
Well I was able to get the ECM info, but it starts programming and then says ECM is not allowing access to program
Old Sep 21, 2007 | 08:40 PM
burgies08ultra's Avatar
burgies08ultra
so if i am following this correctly, if i buy the sert, i can set it up with my computer???
i thought it needed to be dynoed???
burgie
Old Sep 21, 2007 | 09:03 PM
tom73's Avatar
tom73
Yes you can load a map yourself via your own PC. I did. As for tuning the SERT comes with a few canned or standard maps that will get you close. Personally I chose to go this route when I added Rush SlipOn's and AN Big Sucker.You will get the most out of it by having it tuned however since I plan a 103" or bigger build this winter I did not want to spend the money for a tune that won't work with my bike in the Spring.
usecotton
Dec 3, 2007 05:06 PM
pled55
Oct 31, 2007 11:41 PM
BTD
16
Apr 28, 2007 07:52 PM
04harleyboy
Mar 15, 2007 12:37 AM
clayman
Jul 23, 2006 01:07 AM
