cam shaft
Old Oct 9, 2007 | 09:37 PM
steadyflow's Avatar
steadyflow
Default cam shaft
any one know what is the equivalent to a ev27 cam for the twin cam motor, i had a ev27 cam in a evo once and it would pull real strong, i want the same for my twin cam, thanks for yalls help
Old Oct 9, 2007 | 10:27 PM
LowriderFXRS's Avatar
LowriderFXRS
Default RE: cam shaft
The Andrews 26H is supposed to be real close to the EV27.
Old Oct 9, 2007 | 11:52 PM
steadyflow's Avatar
steadyflow
hey thanks lowrider
Old Oct 10, 2007 | 12:09 AM
mentor70's Avatar
mentor70
The Head-Quarters equivilent is the .0039 cam AKA The "Cyclone"!
Old Oct 10, 2007 | 02:14 AM
nsodpty52's Avatar
nsodpty52
Take a look at the woods cams while you are at it. only for ridin dirty. woodscarbs.com
Old Oct 10, 2007 | 03:32 PM
bigdoghd's Avatar
bigdoghd
Zippers 375s is a nice set up also, goes nice with their air cleaner, pipes and the Thundermax.. I'm doing the cams this week and I have it on my dyno myabe this weekend. I've been told 92 HP so we will see.
I'm running the Rinehardt tru duals,T-Max, Zippers air cleaner. Next will be the 103 kit.
Old Oct 10, 2007 | 04:05 PM
Big Peter's Avatar
Big Peter
I installed S&S .510G cams gear drive in my twincam.
Loose the camchain and tensioners !
The tensioners will wear, and this plastic stuff will
kill your oilpump and your engine.
Camtiming is much more precise with S&S gear drive (+ 4 HP)
and no more worries about bad Harley cambearings
(Torrington bearings are included in the S&S set)
www.sscycle.com/modules/instruction/uploads/51-1047.pdf
Good luck on your choice.
Old Oct 11, 2007 | 07:47 AM
Jinks's Avatar
Jinks
Take a look at Nightrider.com's tech pages. They post good specs. of most cams, & you can compair profiles & pick what you like.
star2nv
Mar 5, 2017 08:08 PM
Carmell RKC
EVO
Oct 24, 2016 08:52 AM
94 ultra
2014-2024 Touring Models
Oct 23, 2016 08:44 PM
huffhuff
Jul 19, 2006 02:20 PM
HDF Tech
Engine Mechanical Topics
Jul 2, 2005 03:19 PM
