How Often?
Old Oct 25, 2007 | 12:23 PM
FLHDRIVER's Avatar
FLHDRIVER
Default How Often?
Those that use synthethic and change their own oil...How often do you change it AND do you do the Primary and Tranny every time you change the oil? Longer intervals on the primary and tranny? Just curious.
Old Oct 25, 2007 | 12:25 PM
drdiesel1's Avatar
drdiesel1
Default RE: How Often?
I change my oil every 5K and do the primary and trans every 10K.
I use high quality oils/lubes.
Old Oct 25, 2007 | 12:28 PM
Lost1's Avatar
Lost1
Eng oil w/synthetic (Mobil 1 15W-40) every 4k-5k, primary gets changed with the engine oil as it's unfiltered, and tranny every 10k or 1 year.
Old Oct 25, 2007 | 12:33 PM
NICK56's Avatar
NICK56
motor 3 to 4k
prim 5 k
trans 5k
thats just me.
some go 10k on tranny.. i think book says 10 k on tranny and primary
tranny looks brand new at 5 k
Old Oct 25, 2007 | 01:34 PM
24guns's Avatar
24guns
Not trying to hijack your thread, but...
For those going from dino oil to synthetic, is there any concern with the dino oil that is left in the oil pump and the new syn that is being added?
Do they mix ok or should I get one of those total change kit things that runs the oil out of the pump....eeeeek, still scares me.[]
Old Oct 25, 2007 | 01:57 PM
bigbluff's Avatar
bigbluff
ORIGINAL: 24guns
Dino multi viscosity oils and synthetic oil mix fine. Don't worry about it. Make the switch. The only concern you might have is that on some high mileage engines, when you make the switch to synthetic, youMIGHT see an increase in oil leaks. I don't know for sure how well documented that is. That might be more of an "old wives' tale."
sifularson's Avatar
sifularson
ORIGINAL: 24guns
Good question. I'm switching to syn next week.
Old Oct 25, 2007 | 01:58 PM
bigbluff's Avatar
bigbluff
ORIGINAL: drdiesel1
Same intervals here. I use Amsoil.
Old Oct 25, 2007 | 02:10 PM
old.gezr's Avatar
old.gezr
I use Mobil 1 V-Twin 20-50 in the engine, Mobil 1 45-75? gear lube and Harley Formula + in primary. Change engine every 5K and tranny and primary every 10K. Switched to synthetic at the 1K service and have a total of 10,500 in the 5 1/2 months I've owned it. It works for me.
Old Oct 25, 2007 | 02:13 PM
Peppa1's Avatar
Peppa1
I change them all at 5K using HD Syn3. The primary & tranny could go further but what the heck the cost is minimal. Why chance it ??
