Bag locks
Old Oct 28, 2007 | 10:02 AM
piggy's Avatar
piggy
Default RE: Bag locks
Guys Instead of the wise comments can someone show us (less then handy guys) a pic of the nuts n bolts used to secure the hard bags to the bike, TKs in advance, size of bolt , type etc would help the non handys amongst us, THANKS, Great idea locking bags(Y)
Old Oct 28, 2007 | 10:03 AM
RangeRat's Avatar
RangeRat
ORIGINAL: MNPGRider
ORIGINAL: gunrunner
For what kind of bags? Leather? Harley sells a nice set for 65.00 already, the hard bags dont need them if you kep them locked.
That apparently is what many Harley owners thought, too, right before their bags disappeared and showed up on eBay. Apparently the hard bag factory mounting pins are easily removed with a screw driver from behind. Hence the comments above about people using bolts. Harley now also markets a "bolt" system for the hard bags to replace the pins.
Yep. Thankfully I haven't suffered that (yet).
Old Oct 28, 2007 | 10:13 AM
marvincbr's Avatar
marvincbr
ORIGINAL: MNPGRider
ORIGINAL: gunrunner
Do you have the part # for that bolt system?
Old Oct 28, 2007 | 10:30 AM
Elusive 1's Avatar
Elusive 1
I would like more info. from jeggsr, two post made about hislock system withno detailsofhowit works, looks or anything.
Old Oct 28, 2007 | 01:45 PM
RangeRat's Avatar
RangeRat
ORIGINAL: Elusive 1
Me too. I've been scheming up a way for myself that won't mess up the convenience of the quick-disconnect. Have some ideas but would like to see what jeggsr has to offer.
Old Oct 28, 2007 | 04:44 PM
1flhtk4me's Avatar
1flhtk4me
He might be working on the patent!
Even if you had bolts and nuts to replace the quick twist pins you could still unscrew the bracket bolts ,at least on my bike.
Need some kind of covers to prevent access.
Old Oct 28, 2007 | 04:50 PM
Windup08's Avatar
Windup08
Jegssr, I'm also interested. I would rather be able to unlock mine, then remove them, than have to deal with wrenching...just for the bags...not that I mind wrenching once in a while.
Old Oct 28, 2007 | 05:04 PM
captjon37's Avatar
captjon37
I went to homedepot with the pin and matched a stainless button head bolts, wing nuts, and washers and changed out all 4 for about 10 bucks. Add a little more fun by filling button head with epoxy. Not theft proof but harder.
Old Oct 29, 2007 | 01:58 AM
PapaTravis's Avatar
PapaTravis
ORIGINAL: 1FLTRI4ME
Well, one thing I have read about might help. Get 4 U bolts from home depot, and the appropiate nuts and washers. Drill some holes in the bottom of your bags, and push the U bolts up through the bottom of the bag, going around the bottom bag rail support, and attach the washers and nuts inside the bags. If it has a lid lock, even removing the rear mounting bracket, will not free the bags. They are still bolted on from underneath.Plus, if you ride with iced down beverages (), you have a drain spout.
marshallb
Audio Systems
20
Sep 8, 2024 09:28 PM
TBagger
Touring Parts
Aug 5, 2017 03:02 PM
stewy1200c
Jun 2, 2013 01:42 PM
1hvacmike
Jan 11, 2012 02:11 PM
turbodawg
Jun 3, 2007 09:30 PM
