Hey Phil...I Have about 200kms (125 miles) on my new bike. Should I do your break in proceedure with this mileage still? Id like to get it broken so I can use the cruise control onthe highway.
Absolutely! If it were me, that would be the very next thing I did!
The mechanics and experienced builders I've talked to suggest either following the book recommendations or are a little more conservative. I've got too much invested to follow a recommendation from some internet site that says to run it to the limits and the hell with conventional knowledge. Stuff is made so good nowadays by everyone it'll probably work out OK either way, but I'm not rich enough to take a chance. I will err on the side of caution (and cheat a little now and then).
After 500 miles run it hard and change the oil, trans and primary at 1K. JM.02$
Running it hard will give the rings the proper seating capability from the high pressure gasses created when you load it on acceleration.
I had a friend baby his and it burned oil because the rings did not properly seat. They had to re-ring the bike and start over.
The second time he did as I advised and has had zero problems. The bike now has 10K on the clock.
Loading the rings on deceleration is just as important as acceleration. That's why the post above that states 30-60 and coast back down is important. I have posted that before also myself as the proper way to break in the engine and seat the rings.
If you ever saw how the factory runs these engines up before the bike leaves, you would understand about babying the engine and that it's not the best thing you can do for it.
