Loud Knocking when starting new RKC...WTF?
Old Oct 30, 2007 | 01:56 PM
YodaddyKeith's Avatar
YodaddyKeith
Default Loud Knocking when starting new RKC...WTF?
Hello Gents,
I'm getting a loud "rod knock-like sound" when startingmy new '07 RKC either hot or cold....Just one or two knocks then it sounds ok.
Bike is bone stock with only 150 miles, but has done this from day one. I'm running Chevron super unleaded.
It is also extremely hard to latch into neutral with engine running hot or cold.....I've adjusted the clutch, but it still lurches when starting in gear with clutch squeezed, but clutch lever release is correct. If I pull hard on the clutch cable and check the gap at the lever, it's 1/16", so I know it's right.
Is the starting knock related to pissy EPA fuel map?....And is the clutch/tranny thang related to stock fluids?
My new 07 Sporty (800 miles) expresses none of these quirks and slips into neutral with just a touch....It also starts without any knocking sounds.
Thanks in advance for your replies.
Old Oct 30, 2007 | 01:59 PM
stro1965's Avatar
stro1965
Default RE: Loud Knocking when starting new RKC...WTF?
Are you sure the knock isn't coming from the primary? The new compensator spring assembly bottoms out and knocks once on start-up. MoCo calls it normal on '07's and '08's (big twins). Sometimes referred to as "starter knock".
Old Oct 30, 2007 | 02:03 PM
fryeca's Avatar
fryeca
I was told that the compensating sprocket on my '06 is the culprit that makes that noise, not sure if the 96" has the same primary guts that mine has. They said the noise is when the sprocket bottoms out under the start compression stroke and that it is normal.
Old Oct 30, 2007 | 02:04 PM
glide's Avatar
glide
The loud bang is due to the compensator setup that they have in the new bikes. I don't think there is any that don't do it.
The neutral thing will get better with miles but a good gear oil in the trans will work wonders for you here like Mobil 1 75/90 or spectro 6 speed trans oil.
The free play at the bars is only cable free play and the actual clutch adjustment is done in the primary. The lurching is an indication that the plates are not seperating enough unless it is the formula+ that is in the primary causing it. Formula + is basically 50Wt oil and in the cold can cause some drag on the plates. Try redoing the adjustment in the primary and see where you are at with the turns out after cracking loose the locknut. Should be 1/2 to 1 turn counterclockwise from the lightly seated position. If you are over 1 turn out, this may be your problem.
Old Oct 30, 2007 | 02:06 PM
glide's Avatar
glide
ORIGINAL: fryeca
Your 06 shouldn't have the knock associated with the 07 and later bikes. It is an entirely different setup on the compensator.
Old Oct 30, 2007 | 02:08 PM
Comfortably Numb's Avatar
Comfortably Numb
Yup, what they all said. Mine started doing it at about the 15000 mile mark, only it kept up until the bike warmed up completely. That's what it was.
It's pretty scary.
CN
Old Oct 30, 2007 | 03:12 PM
24guns's Avatar
24guns
ORIGINAL: Comfortably Numb
It's pretty scary.
CN
My 06 knocks until the oil flows a bit too. I always thought this was a lifter knocking. Could be, still doing it at 27K.
So you are saying 06's can be have the compensator knock as well? I'm a little confused, as normal.[X(]
Old Oct 30, 2007 | 03:29 PM
bigdoghd's Avatar
bigdoghd
Hmm.......knock, clatter, ticking noise, vibration we are talking a Harley? Sounds pretty normal to me.
Old Oct 30, 2007 | 05:28 PM
thatguy's Avatar
thatguy
A single LOUD knock at startup is normal.
Old Oct 30, 2007 | 05:34 PM
electaRICK's Avatar
electaRICK
07 and08's have this new unique feature,,, when you hit the start button,,, bang,!! ,,its to make everyone
notice your new bike,, and they all have it!!
after 1.000 miles and a oil change your bike shifting will be as smooth as butter!
we've all been there,,, dont worry
