Performance upgrades...what to do first??
Old May 21, 2008 | 10:51 AM
  #51
FastHarley's Avatar
FastHarley
Former Sponsor
Default RE: Performance upgrades...what to do first??
The bike is made to ride. That is job #1.
*Put a good suspension on front & rear. Now the bike will ride much better, corner better, does not beat you to death like a bagger does. You can enjoy your ride. Only a person who is an experienced rider with discerning taste will appreciate this upgrade.
*Put on good brakes on that stop you in all conditions, do not cause friction, and work well.
*Put good lighting on that you can see at night.
Let me see, rides good, stops good, can see at night. Go from there. Leave the chrome & paint for last unless, of course you spend your riding time at the bar talking about riding.
Old May 23, 2008 | 12:21 AM
  #52
Strokah's Avatar
Strokah
6th Gear
Nice, FastHarley. Suggestion is to leave your scoot as is. Each to their own of course, that's what drives us to unique.
Old May 23, 2008 | 06:10 AM
  #53
FastHarley's Avatar
FastHarley
Former Sponsor
ORIGINAL: Strokah
Let me clarify my post.
The question is what to do first. I answered that in my own opinion.
I said: get your bike to ride well & be comfortable, stop in a shorter distance than those POS stock brake pads, and change the lighting. Once you get your bike to use the road well than modify it to go faster (next step). These bikes new do not handle what they have already (HP) much less make them faster. Paint work is your choice in build/modification order but if they were ridden than that is not so much of an issue as is chrome.
I am saying: Get the bike to ride right first if you plan on riding your bike. If your bike to you has the function of a nose ring or just a possession than the order of importance is different than mine so you should do what you like. On my dresser, there is only 2 things stock on it (1 is modified [frame]) & that is the title & the frame. Nothing left of HD. Now I have used a 124 S&S, C/F wheels, my own body work, inverted front forks, radial brakes & 320mm rotors,a modified frame with a 22 degree rake (I raked it but the other way) shortened the frame by 2 1/2", developed a new wrap around gas tank that is a smooth top, and I am not no where done. I am currently developing a HID 35 watt/each set of passing lamps. both 3" & 4 1/2" as well as my main light. I am using a headlight bucket and my own detachable frame mounted front fairing that looks like a Hayabusa type of shape for aerodynamic features & enclosed/integrated attached lowers & vents. The whole body work comes off and the bike looks like a large FXR. The shocks are not in the same position either. By the way I will chrome some & give the bike a paint bath.
Old May 23, 2008 | 09:02 AM
  #54
Leftcoaster's Avatar
Leftcoaster
Great reply FastHarley, you brought up something most riders never think of and you're right. HD gets a ton of cash for their product and puts some truly poor suspension and brakes on them. Old school doesn't begin to describe the ancient design used front and rear. Stiffen the chassis, fix the forks and add some decent shocks to ANYbagger and you'll smile every time you drag the floorboards. Ditto with the brakes.Anyone who is truly a riderwill appreciate this advice.
When yougo after the motor almost any combination of a/c, pipes, and ecm will add 10 hp-lbs/ft. but youshould do all three. You might get lucky and find a canned map that will work but there's nothinglike a good tuner and some dyno time. Money well spent and your bike will JUMPwhen you shift to 2nd and 3rd and still get 45+ mpg.
Old May 23, 2008 | 01:54 PM
  #55
Coffee's Avatar
Coffee
I just installed the Stage I listed below, and couldn't be happier with the change.
According to the Dyno results, my HP is now 75.38, my Torque is now 88.31, and my fuel economy has increased 30 miles per tank.
Plus the True Duals rumble like a Harley should.
snowdevil23
2014-2024 Touring Models
Sep 30, 2014 07:39 AM
atlantaallen
Apr 18, 2013 03:24 PM
Gator KStenz
Apr 20, 2009 02:38 PM
jimsz06racin
Dec 8, 2007 08:30 PM
SimonW
Oct 8, 2006 09:44 PM
