HD Oil or GEARSAVER
Old Nov 7, 2007 | 09:41 PM
Nathan918's Avatar
Nathan918
Default HD Oil or GEARSAVER
For 2008 6 speed transmission anyone here use "Gear Saver". I was told it isbetter and used more than HD SyntheticTrannyOil.
I was told it will shift better, smoother Etc.
What do you guy's use? and Why?
Thanks
Old Nov 7, 2007 | 09:46 PM
Jim Dawson's Avatar
Jim Dawson
Default RE: HD Oil or GEARSAVER
I didn't know HD made aSyntheticTrannyOil.
Old Nov 7, 2007 | 10:25 PM
Nathan918's Avatar
Nathan918
I'm sorry I meant HD TransOIL not Synthetic.
Let me try again. What Tranny oil do you use?
If you have tried Gearsaver what are your thoughts?
Old Nov 7, 2007 | 10:28 PM
Jim Dawson's Avatar
Jim Dawson
I've never heard of Gear Saver so I can't help there. I use Amsoil 75W90 synthetic gear oil because I can get it at my HD dealer.
Old Nov 7, 2007 | 10:53 PM
redneckremi's Avatar
redneckremi
The "gear saver" I use is from Bel-Ray. I changed at the 1000 mile mark and went with Royal Purple. Reason being myinner thighwas getting cooked every time I would ride from the heat. Now that it is cold here, I sure coulduse that heat again. No really, it does shift smooth, you will still hearthe "clunk" when you shift but it does seem to be smoother especially trying to get into neutral. I would highly recommend it. IMHO! Remi
Old Nov 8, 2007 | 08:07 AM
Scootr's Avatar
Scootr
I am getting ready to change the trans fluid using the Redline shockproof heavy. It's been getting a lot of good reviews from the folks here. Will report the results when I get done.
Old Nov 8, 2007 | 11:57 AM
madurodave's Avatar
madurodave
I use Mobil 1 75-90 Synthetic Gear Oil in Spring and Fall, Mobil 1 90-140 Synthetic gear oil in the summer. Very smooth shifting, great performance so far.
Old Nov 8, 2007 | 12:01 PM
chiefparry's Avatar
chiefparry
ORIGINAL: madurodave
Big difference when I switched to the Mobil 1 Syn gear oil. Nice and smooth now.
Old Nov 8, 2007 | 02:15 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
I use Mobil 1 75w-90 Gear Lube year round in my SE 6 speed.
Old Nov 8, 2007 | 02:52 PM
HogBoy's Avatar
HogBoy
I use Redline MTL in my primary; Shockproof Heavy in the trans. Mobil 1 in the main hole. Life has been good.
