Would anyone be interested in these??
Old Nov 24, 2007 | 09:56 PM
continentaldrifter's Avatar
continentaldrifter
Default Would anyone be interested in these??
Got bored and came up with these....let me know what you think
Wanted a different look for my front whichways. So removed the originals from sides of front end, and replaced with a set of PIAA off-road driving lights (extremely bright). For my idea i was going to recess a 9 light LED strip into my engine guard. This came to be welding a coffin for the LED strip then cutting the recess into the guard. Then when positioned perfectly tig welded then ground and filed to a nice smooth radius on all four sides of "coffin". Then tapped two holes,cut to fit the snug fitting gasket and drilled an access hole on top of engine guard under neck but on the bottom side of tubing so no water can get in.Powdercoated and sunk light strip in its position, ran wires up and inside engine guard exiting through a tight grommet around access hole. Simply re-wire to existing oem directional wires and WHALLAAA!!.............If this is something that someone is interested in shoot me a PM. Only thing is, im not close to a chroming plant so if you want chromed you'd have todo that yourself, but powdercoat, no problem........
[IMG]local://upfiles/32005/FAED23F4A2104F76AFCA1264B9B57D62.jpg[/IMG]
[IMG]local://upfiles/32005/FD10A8540B1E45EB9302214436DFEA03.jpg[/IMG]
Old Nov 24, 2007 | 09:58 PM
continentaldrifter
Default RE: Would anyone be interested in these??
pics 2 & 3
[IMG]local://upfiles/32005/186A4DDF020B4F8AB8C27D6C25818044.jpg[/IMG]
[IMG]local://upfiles/32005/DA23F5BBEAA240E3AE0C005162596A1C.jpg[/IMG]
Old Nov 24, 2007 | 09:59 PM
metal_mike's Avatar
metal_mike
nice mod
Old Nov 24, 2007 | 10:01 PM
continentaldrifter
Pic on the bike. How can i load a video?
[IMG]local://upfiles/32005/DBEBBF6C7D7247A58A54BF16D0D30B69.jpg[/IMG]
Old Nov 24, 2007 | 10:41 PM
cowboyglide's Avatar
cowboyglide
ORIGINAL: continentaldrifter
Now that is pretty cool! Nice job of fabricating. Really unique.
Old Nov 24, 2007 | 11:43 PM
continentaldrifter
Thanks, just wanted to be a little different
Old Nov 24, 2007 | 11:57 PM
CREEPSHOW's Avatar
CREEPSHOW
Very nice work,but do ya think there is a weak spot there if ya dump the bike? Just wondered?
Old Nov 25, 2007 | 12:05 AM
Paniolo's Avatar
Paniolo
Are there lights that would fit in there that are powerful enough to throw out over some distance?
Something like driving lights as opposed to markers. I like the ideabecause they can work on bikes with lower fairings.
Old Nov 25, 2007 | 01:37 AM
olgreydog7's Avatar
olgreydog7
Very clean work. I love to see good home fabrication.
Old Nov 25, 2007 | 02:12 AM
sublime_ac's Avatar
sublime_ac
That's pretty slick.. I like it..
